Sound Deadener Installed With Pics
Old Jun 25, 2005 | 02:03 AM
fonseca's Avatar
There's a very noticeable reduction in road noise when you do the whole car. If that's your goal, start with the doors and floor.
That latch on my tailgate is loose too, very annoying.
Old Jul 14, 2005 | 10:24 AM
Loneshark's Avatar
Vehicle: 2000 Tiburon
very nice !!! looks well done !!!
i was looking through your posts, searching for the grommet that you put your amp wire through from th fender into the cabin, so on my 2000 tib, i removed the inner fender and found a tube looks like a drain, is that where I want to run the amp wire through ??? does that tube even lead intothe cabin ?? maybe next to the interior fuse panel ??? well Im gonna take a better look right now !!!
can ytou send me some pics or lead me in the right direction ?? thanks dood
Old Jul 14, 2005 | 11:18 AM
firebug21's Avatar
^Loneshark
Its like a black plug looking thing. If you remove it you can see the opening through the hole. In the car if you look to the left of the fuse panel under the dash there might be what looks like a rubber mat (if you have it) and behind that is the opening which leads to where the hole is.
I am not home right now, but if you need a pic of what I am talking about I can get one to you this weekend.
Old Jul 14, 2005 | 12:59 PM
auburnfan's Avatar
Been looking at mine as well and it is making a lot of noise too. I am looking at trying to get something like a piece of a vacumm hose. Cut to fit then cut the side of it to slide over then tape close. Will that work or is that a bad idea?
QUOTE (Zman @ Jun 24 2005, 10:12 AM)
That little piece of Shh...t is guilty! I am not a big fan of audio setups (I mean with subs and amplifiers; besides I don't have the money for that smile.gif ) but I have a rattling noise from the back also, I striped the back the same way you did, and the only piece to guilt there is that one. A dealer mechanic told me the latch itself makes a little noise, but I am trying to figure out how to get rid of it. If only I could get it out, maybe wrapping it with a vacuum hose could make it vibrate less... I don't know. But please, if you do find a solution (and by the pics it seems you are pretty decide to do it) , post a DIY on it
Old Jul 14, 2005 | 02:23 PM
fonseca's Avatar
This is the grommet you're looking for. That's a flexible grabber in the pic, which really makes running wire easy.
