Someone Try Figuring This Problem Out..
Old Jul 13, 2005 | 07:27 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Okay, I take off my dash just to check some connections back there. I put my dash back. Then I check to see if my blower works and yes it does it air comes out from vents near windows for defogger but when I switch it to the vents for the passanger ( 2 front 2 door ) it doesn't switch.
So air comes only from the vents near the window to defog the windows. I don't have AC installed and yes I connected the vacuum lines for the dash tongue.gif
What's going on?
I traced the red yellow blue ( i think i can't remember rigth colors right now ) vacuum lines to these 2 what look like vacume cylinders near the gas pedal. I pressed down on the cylinder then the air switched to legs. So I'm thinking something wrong with those? Or the switch is not working? I'm not sure I don't know anything about this..
Old Jul 13, 2005 | 11:43 PM
Double_A's Avatar
I had the same problem dude when I took my dash apart. I thought there was a leak in one of the lines, but i think they just had no vacuum until i switched it a bunch of times. I just played with it for like 2 days and then it finally worked again.
Old Jul 14, 2005 | 03:47 AM
tanc's Avatar
You just played with the switch untill it worked?
Old Jul 14, 2005 | 07:52 AM
Viper's Avatar
You can play with other things but I doubt it will fix your blower system lmao.gif
I had no problem, removed my dash 2 many damned times. you sure you reattached the 'clear' hoses at the back right
Old Jul 14, 2005 | 03:08 PM
tanc's Avatar
Clear hoses were attatched. I found out the problem.
The black hose that control the vacume preasure was not sitting tight on the cylinder nose near the gas pedal.
