Project F8
Old Apr 17, 2012 | 03:50 AM
  #31
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
Originally Posted by 300D50
Have you had any belt slip issues?
The only issue i had when the guy put the belt on last they lost a part so the OEM betl tensioner was rubbing on the dust cover so i spaced it with a washer and i don't know if it is the quality of belt but it's cracking ???
Old Apr 17, 2012 | 03:57 AM
  #32
300D50's Avatar
Oh god. More ideas struck me...
If I used 2 pulleys on the supercharger, both with sprag clutches, and used electric clutches on the jackshafts, I could run 2 different pully ratios, and have 2 distinct boost levels...
Old Apr 17, 2012 | 09:23 PM
  #33
This way lies madness. Don't try to make her perfect she'll never hit the road.
Old Apr 17, 2012 | 09:28 PM
  #34
300D50's Avatar
Yeah, that's for sure.
It's an interesting thought experiment though.
More cad work today, did some mock-up with plotted paper and got ready to machine the top plate tomorrow.
Old Apr 18, 2012 | 04:19 AM
  #35
wheel_of_steel's Avatar
Not saying you should do this, but if you were, how would you transmit the drive from two differing pulleys to the single supercharger shaft?
Old Apr 18, 2012 | 09:42 PM
  #36
300D50's Avatar
After a 5 hour bath! So worth it to have it spray tanked, saved me some serious time!
Wheel:
As for 2 pulleys one charger, I'd use a sprag clutch in each pulley on the supercharger end, so that the charger can freewheel fully if needed.
Old May 8, 2012 | 11:32 AM
  #37
300D50's Avatar
Bought:
16 valve stem seals
9 intake studs
9 exhaust studs
Timing chain guide
4 spark plug tube oil seals
Cam oil seal
Getting there...
Nearly ready for my oil flush and change this weekend, just need to get another quart of mobil 1 in 15W50 for the flush.
Oh, and weather permitting, COILOVERS go in!
Old May 8, 2012 | 11:11 PM
  #38
Duh low! What coilovers did you go for?
Old May 9, 2012 | 04:42 AM
  #39
300D50's Avatar
I ordered a set of Megan Racing ones last year, before my other car was wrecked.
I already scrape mudflap over potholes, so no low for this car right now, just a better suspension.
Solid mount camber plates... This will be fun...
Old May 9, 2012 | 05:00 AM
  #40
Damn I just noticed this thread. Total badass. I can't imagine how many hours you put in this. Can't wait to see it finished!
