Project F8
Old Mar 14, 2012 | 11:46 PM
300D50's Avatar
The intercooler core came in monday, but I haven't had time to post anything till now(when I should be sleeping...)
I now can get a feel for how the end tanks need to be designed, as well as the flange surface of the manifold.
Old Mar 15, 2012 | 06:04 AM
wheel_of_steel's Avatar
Whoa, that's fantastic dude! I didn't know you were moving to supercharge your Tib.
Just to confirm, is that a beta II manifold that has been reshaped to fit the intercooler? The fabrication is looking shcmicko.
Old Mar 21, 2012 | 12:01 AM
300D50's Avatar
Put the low-pro tires back on yesterday, too warm for studded.
Both drivers side valve stems suffered catastrophic failure when attempting to remove the caps, which was fixed by replacing the stems with new ones.
Tomorrow I get the pass side done as preventative maintenance.
It feels SO good to have my full lock-to-lock steering back! Tighter turn radius =awesome.
Now to get the coilovers in sometime soon.
Manifold needs to be machined some more before I can weld the mount plate on, but it's getting there.
It is indeed a Beta II manifold, off a cvvt engine. I decided it would be easier to work with than screwing around with a sheet metal intake and all that happy horse crap...
Old Mar 24, 2012 | 02:39 AM
300D50's Avatar
The intake went back on the mill this past wednsday to get another 0.25 taken off to accommodate the mounting plate that the intercooler and supercharger will bolt to.
Slowly we're getting there...
Old Mar 24, 2012 | 01:20 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
This is some awesome machine work, love it and looking forward to more updates.
Old Mar 25, 2012 | 02:40 AM
300D50's Avatar
Pulled a Beta II head this morning, so I should be good to go for solid tappets when I do my timing belt in another month or so.
Old Mar 27, 2012 | 02:35 AM
300D50's Avatar
Yesterday was spent removing the clutch from an AC compressor in order to adapt it to the jackshaft setup I'll be using.
Things are getting there...
Old Apr 10, 2012 | 07:48 PM
300D50's Avatar
More progress!
The clutch drive is starting to take shape, but still needs a few more hours of cad work before I can fully machine it.
As far as the manifold goes, I've spent most of the day in Inventor working out how everything is going to piece together.
I've worked out a much easier way to route the coolant to the outside world, and solved a few mounting constraint issues as well.
Sorry there's not any eye candy, but I'm stealing seconds away from putting the coolant passages in the mounting plates and running flow calculations...
Old Apr 15, 2012 | 08:35 AM
300D50's Avatar
Woohoo! AUDM grab handle is installed!
Took 2 hours, almost all of it carefully pulling down the headliner...
Old Apr 16, 2012 | 03:59 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
is that intercooler able to flow enough air evenly to all cylinders? it looks like 1&4 would be obstructed by the end tanks for the water to air-...
also does the intercooler have enough depth for the boosted air to provide a significant cooling effect?
more pics!!!!!
