Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
tranny swap?
Old Aug 28, 2002 | 08:38 PM
  #21
Noel's Avatar
I hear about three cars with BETA turbocharged engines with a trans from Scoupes. They said that are a lot stronger that stock Beta trans but you got to modify a couple of things. Since they swap this trans they never have problems with them again.
Now ONPOL will begin with this project eliminate his trans problems. The only problem is that you will have closed ratio gears, better acceleration smile.gif but more fuel burned. frown
Old Aug 29, 2002 | 02:05 AM
  #22
JAWS 021's Avatar
didnt the S coupe have the mitsu engine?
Old Aug 29, 2002 | 02:16 AM
  #23
Dopeskills's Avatar
As I recall.... UFB was offerring an upgrade for the 5 spd Beta tranny.
The KORE drag axles might not be a bad idea either.
Old Aug 29, 2002 | 02:29 AM
  #24
JAWS 021's Avatar
UFB???
wow
i didnt know that
As for axles... you can get stronger axles, but your differential will still shatter into millions of pieces
The old mitsu galant tranny would rule
AWD!!!
Quaffie is the only solution, unfortunately frown
