Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
tranny swap?
Old Aug 26, 2002 | 03:43 PM
Shadohh's Avatar
you plan on getting $2200 for your manual tranny and ECU? AHAHAAHAHAHA
You will get $1000 at most. $700 for the transmission parts and $300 for the ECU. And their is no such thing as a manual ecu and a auto ecu.
Hyundai uses one standard ecu, and has a TCM for the automatic, its a sperate device, not combine like ford does.
[ August 26, 2002, 10:43 PM: Message edited by: Shadohh ]
Old Aug 26, 2002 | 04:20 PM
JAWS 021's Avatar
no man... i ment i will sell it for 1000
I think someone would rather trade ecu's than to have all the CEL problems you and 2unique had
A straight ECU swap would make things simpler
AHhhhh... the hell with this
Quaffie is my only choice
Old Aug 26, 2002 | 07:04 PM
Shadohh's Avatar
Trading ECU dont do ****.
As I said. Hyundai Makes a Generic ECU.
Putting in an ecu from a manual car will sitll cause a CEL. WHy? Cause like I said, Same ECU.
You need to rewire your ecu to put it in manual mode.
How exactl is red making you paranoid? Transmission should hanlde 250whp and if you are making more WHP then that, then you certainly have the money into buying a quaiffe transmission smile.gif
Or what I would do, it cyro the standard tranyy
it makes the whole unit stronger.
Old Aug 27, 2002 | 05:35 AM
JAWS 021's Avatar
250whp... muahahaha
im going for 50 more buddy
wink
Ill eventually get an LSD... but for now im working on getting the 300whp first
Old Aug 27, 2002 | 06:44 AM
Shadohh's Avatar
::points to what he said:: If you can pay for 300whp, you can pay to get the tranny beefed up.
Local transmission shop or cyrogenics shop.
300whp is alot of power.
why not ask onpol what he is doing, he seems to know his **** very well.
I am sure he has plans for his transmission.
If you tranny is not properly prepped for such power you can lose it all. tranny, wheels, axles, engine parts....
What are you doing about your axles?
[ August 27, 2002, 01:48 PM: Message edited by: Shadohh ]
Old Aug 27, 2002 | 06:54 AM
JAWS 021's Avatar
i trust the axles at 300whp
i dont trust the differential
Old Aug 27, 2002 | 08:53 AM
Shadohh's Avatar
Why not just get an older diff, and get just the diff frozen? thats if you wanan be cheap about it.
Old Aug 27, 2002 | 12:13 PM
skierd's Avatar
Vehicle: 1997 accent L
Isnt the part that cause the diff to fail one of the pins in the diff? I think a lot of the neon peeps simply weld that pin in place to stop if from sliding out under load and breaking the diff. I'd get it cryo-treated too.
I also remember onpol saying something about twisting axles at 225whp.
Old Aug 27, 2002 | 03:01 PM
Shadohh's Avatar
Yeah, but onpol twisted his axles at 225whp, with a elcheapo Phantom Grip LSD.
To be honest, you put a real LSD in their, and alot more is going to be broken just axles.
Old Aug 28, 2002 | 08:03 AM
JAWS 021's Avatar
i dont think korea has had any problems with axles
im guessing its the ****ed up phantom grip LSD
