2003 accent
Old Jun 16, 2009 | 08:40 PM
03AccentVA's Avatar
Vehicle: 2003 Hyundai Accent
<div class='quotetop'>QUOTE(accent03 @ Jun 16 2009, 08:54 PM) </div><div class='quotemain'>accentva does the ebay one sound good?</div>
It's not too much of a differance in normal driving, slightly deeper when pushing it. I don't know if its common but the part I like is it has a slight whistle when the pedal is over around 70%, and you can hear the air going in (hard to describe) when I hit the gas sharply (the bung is plastic not welded on), it sounds different but clean and not bad at all, I really like it.
BTW: welcome.gif
Old Jun 17, 2009 | 12:34 PM
Yellow03Accent's Avatar
<div class='quotetop'>QUOTE(03AccentVA @ Jun 16 2009, 10:40 PM) </div><div class='quotemain'>It's not too much of a differance in normal driving, slightly deeper when pushing it. I don't know if its common but the part I like is it has a slight whistle when the pedal is over around 70%, and you can hear the air going in (hard to describe) when I hit the gas sharply (the bung is plastic not welded on), it sounds different but clean and not bad at all, I really like it.
BTW: welcome.gif</div>
As for the big question, did you really even notice a difference in power after it was installed?
Old Jun 17, 2009 | 01:57 PM
I noticed a difference after installing mine. I got slightly better mileage and had better throttle response.
With the following mods I made 100whp and 109lb/ft:
Short ram intake with K&N filter
Evofusion header
Magnaflow hi-flow cat
Custom 2.25" catback with Apexi N1 clone muffler
That's compared to a stock 1.6l which makes about 80-85whp generally.
Old Jun 17, 2009 | 03:23 PM
03AccentVA's Avatar
<div class='quotetop'>QUOTE(187sks @ Jun 17 2009, 03:57 PM) </div><div class='quotemain'>I noticed a difference after installing mine. I got slightly better mileage and had better throttle response.</div>
Although I noticed a large increase in gas milage the standard seem to be a slight increase (It may just be the way I drive + all highway).
Old Jul 16, 2009 | 09:50 AM
Evofusion header
That's compared to a stock 1.6l which makes about 80-85whp generally.</div>
Wow that's not bad. How loud is it? Got any clips?
Old Jul 16, 2009 | 11:19 AM
It's somewhat loud, I guess for lack of a better scale to use. It's much quieter than when i was running open header for a few days (by like a factor of 5) but it's far louder than stock.
Sure I have lots of videos.
Idling
[youtube]gp2woPO78K8[/youtube]
0-60 pull from inside
[youtube]Q0PH5fnr5Tk[/youtube]
Autocross runs from outside
[youtube]zQLenDhnCCk[/youtube]
[youtube]iq6nT93VJHw[/youtube]
Playing in the snow
[youtube]tHnzXOoF31I[/youtube]
On dyno
[youtube]ELbwhC2rwDE[/youtube]
Tray sliding
[youtube]JyyRHZhFQQ4[/youtube]
Cruising
[youtube]rVCOdZ4973w[/youtube]
Old Jul 17, 2009 | 10:36 PM
1sickgs's Avatar
<div class='quotetop'>QUOTE(accent03 @ Jun 16 2009, 02:03 AM) </div><div class='quotemain'>my friend has blown up so many eclipses but how cheap for the full cold air?</div>
What do you mean by that? Aluminum piping is aluminum piping. Its not really going to matter what car you take it from. Your friend must be blowing fittings because of too much boost. A non-boosted Accent should never have that problem. But anyways, you already have your intake. Guess I'm just mad cuz I'm one of the pioneers for the eclipse intake.
Maybe I should just convert it to full CAI. All I need is a coupler and another foot or so of piping.
Old Jul 19, 2009 | 10:48 AM
<div class='quotetop'>QUOTE(187sks @ Jul 16 2009, 01:19 PM) </div><div class='quotemain'>It's somewhat loud, I guess for lack of a better scale to use. It's much quieter than when i was running open header for a few days (by like a factor of 5) but it's far louder than stock.
Idling
Playing in the snow
On dyno
Tray sliding
Cruising
[youtube]rVCOdZ4973w[/youtube]</div>
Wow doesn't sound bad at all. Also love what you did with the tail's. The tail lights on these cars are one of my favorite things about them.
Old Jul 19, 2009 | 11:06 AM
Thanks!
I really like the tails too, and I also thought the design looked really good from the factory compared to most tails at the time.
