Random help please!!!!!!!!!
Old Aug 1, 2001 | 12:09 AM
Jaws99's Avatar
But is the sensor you showed me in the picture the right one? Reason being is ther is one by the wxhaust manifold to the right and I thought maybe you might have thought I wanted water pressure and so you showed me the picture of the one installed on the side. If that is the one what is the sensor on the block to the right of the exhaust manifold?
Old Aug 1, 2001 | 12:39 AM
Jaws99's Avatar
Also what wire do I tap there are two wire coming off the sensor and if I hit the hot one it will pop the gauge. And if it is the one by the manifold I tried tapping the wire when you turn the car on the gauge goes up to 100 psi and then drops to 0 psi and doesn't move after that.
Old Aug 1, 2001 | 02:02 PM
Jaws99's Avatar
Radom you have a private message
Old Aug 1, 2001 | 02:05 PM
Not from you I don't. E-mail me.
Random00@mindspring.com
