Sputtering @ Low RPMs
Old Sep 30, 2004 | 03:14 PM
Supermanwoot's Avatar
Default FS - Momo shift knob
clutch messed up at all? you may have to tighten the cable, but its most likely some sort of sensor.
Old Sep 30, 2004 | 04:01 PM
javageek's Avatar
Default Re: Getting Car turbo ready
I have this same issue with my car. I have done everything from Chemtool, Cleaned Air Filter, changed fuel filter, etc. Nothing has worked so far. 97Tibby, are you serious?? If so, I will be super happy!
Old Sep 30, 2004 | 04:02 PM
blacktibby's Avatar
Default Re: Sputtering @ Low RPMs
Mine was doing the same thing last week i just threw a bottle of injector cleaner into her and she has been great since!..
Old Sep 30, 2004 | 07:03 PM
Default Re: Gentex Rear-View Mirrors
You guys MAY want to look at your plugs and wires too.
Old Oct 1, 2004 | 03:16 PM
Sooperdoopermann's Avatar
Default Re: CAR SHOW IN NJ on 10/03 anyone going???
I put a new set of plugs and wires in the day it started, thinking it was just a tune-up issue.
Old Oct 4, 2004 | 09:33 AM
1997tibby's Avatar
Vehicle: 02 Accent
Default Re: Fuel Management
well, the coolant temp sensor tells the ecu how much fuel to deliever, if the coolant temp sees the engine too cold it literaly dumps fuel into the engine to try and warm it up, if it sees the engine hot, it reduces the amount of fuel to deliever. My problem was that it thought the engine was cold so i was running extremely rich and the spark plugs i had in there werent hot enough plugs to ignite the amount of fuel, it was basicly fouling out my plugs. the sputtering is more fuel igniting in one cylinder then another and the amount of fuel that the spark plug ignites is different on each revolution! if you have any other questions, or require further explantion, please feel free to message me. hope this helps.
Old Oct 5, 2004 | 04:55 PM
Default Re: help need cheap hp
OK I TOOK IT TO THE DEALER TODAY (AFTER FINDING OUT I STILL HAD A WARRANTY) TURNS OUT IT WAS SOMETHING WITH/IN THE COILPAK, THE GUY ON THE PHONE WASNT VERY CLEAR, BUT HE TOLD ME HE FIXED THE PROBLEM AND I DIDNT CARE. I APPRECIATE EVERYONES HELP,
THANKS EVERYBODY.
Old Oct 5, 2004 | 05:39 PM
Sznurek's Avatar
Default Re: Very bad luck
Same thing happened to me before. Clean your TPS and you should be fine.
