Shift Improver Kit
ya barely anyone knows about it which is weird because its such a good upgrade...but ya it definitely would not be cheaper to switch to an m/t...getting the shift kit for an american transmission is only around $100, and yes it would be harder to get one (if there is one) for the import tranny's we have so it will be more expensive...buuut ive already looked into changing my tib to a m/t and it would be around 7k (mostly from labor), since i wouldnt know what the hell im doing
If you get a used tranny, a manual swap with labor would probably be only around 3k-3.5k. Getting an auto tranny to run with a manual in the quarter mile area we are talking about (12 seconds and above) will require a torque convertor, probably a tranny cooler, and messing around with the internal veins... which will be just as much as swapping to a manual and getting a good strong clutch and flywheel.
QUOTE (shark2)
ok so scenario:
you have two equal tiburons but one is stick other auto...if both were were upgraded to max which would be faster? stick right?
It takes more involvement and more money to get the auto tranny to match the 5speed.
