Motoria 4-2-1 header quality Q's?
Old Jan 6, 2005 | 08:06 PM
  #21
hamhead's Avatar
Default Re: Motoria 4-2-1 header quality Q's?
Yep. Probably won't be exact fit though.
Old Jan 6, 2005 | 08:08 PM
  #22
Blu_Drgn's Avatar
From: Lillington, NC & Maryville, TN when I can get there
Default Re: Warning!!! stay away from AIRBAGIT.com
Well I meant get an exhaust place to do it, but you get the general idea.
Old Jan 7, 2005 | 02:46 AM
  #23
Default Re: Insomniac Thread
QUOTE (blu_drgn)
So you would just cut out the test cat and weld a highflow in its place?
I only suggested the high flow cat because the test-pipe/cat could cause you some grief for emissions & whatnot... could be a lil' loud too but you should just see how you go with it on first (if you get this setup).
If you look at the pics you'll see the test-pipe/cat is actually a separate section on it's own, with a 2 bolt flange on one side & for some reason a 3 bolt flange on the cat-back side (presumably to cater the cat-back more for RD2s?)... Just get the shop to use the same type of flanges on the high-flow cat if you get one... that way you can just swap them over if you want to.
Old Jan 7, 2005 | 06:38 AM
  #24
UltraTibby's Avatar
Default Re: NEED SOME MORAL SUPPORT, FROM FELLOW OWNERS!!!
The test pipe that these headers come with WILL make you throw a cel. Been there done that, before I got my high flow CAT. It is also loud as hell and kinda tinny sounding.
Old Jan 10, 2005 | 03:47 PM
  #25
Here's the link
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WD2V
