Info on bbtb
Old Aug 19, 2014 | 06:54 PM
  #21
next up.
do you have a way to adjust the fact that the TPS reads closed differently?
Old Aug 20, 2014 | 11:52 AM
  #22
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
When I get the chance, thought about tweaking the orientation of the tps when installed to see if it helps any. Did you do anything differently when you installed yours?
Old Aug 23, 2014 | 09:45 AM
  #23
So I was toying around with the tps and unbolted it so that I could maneuver it around with the car running and when I twisted it towards the passenger side, the idle came down. So seems like a voltage issue to me. Figured my options were to wire in some resistors or mod the tps bolt hole so that I can crank it back to where I want it and have a decent idle. Opinions?
Old Aug 23, 2014 | 04:20 PM
  #24
The voices tell me somebody did mention they had to alter mounting holes so a TPS would orient properly for close-at-idle readings.
Old Aug 24, 2014 | 07:52 AM
  #25
I wouldn't be surprised if that were the case.. I found the stock voltages for the tps and plan on going out with my multimeter to see what they are.. hoping that is the issue so I can go from there.
Old Aug 24, 2014 | 11:51 AM
  #26
So I found this while combing through the forums earlier:
MAX voltage at 100% throttle is between 4.25-4.8 V. It should read between 0.25-0.8 V at idle. Power input to the TPS should be between 4.8V and 5.2V.
With that being said I checked the voltage at idle and it was around 1.0 and at max throttle was around 4.6.. when I tweak the tps sensor orientation the lowest it will go is .68 and then max throttle is around 4.4. Looks like I need to widen out the sensor holes a tad and should be good to go.
Old Aug 24, 2014 | 04:41 PM
  #27
REALLY?
yeah...I did 3 f*cking posts above you
that's bad. Even for you.
Old Aug 24, 2014 | 06:53 PM
  #28
I appreciate stockers response but the idle suggestion from faith wasn't straight forward..
But besides that, I've gotten the idle down from around 2k to about 1.2k at the moment. Need to bore out the tps hole some more and then should be good to go.
Old Aug 24, 2014 | 09:11 PM
  #29
You dropped a hint, faith. As men, we are free to ignore hints and wait for plain language. For all any of us know, you were talking about a complicated electrical solution to shift the voltages, or maybe using a trained monkey.
Old Aug 24, 2014 | 11:31 PM
  #30
a hint?
any piggyback/standalone worth a damn has a tps correction built in. mine was as simple as: press button. step on gas. hold. release gas. done.
since when is
a hint?
