Fuel pump replacement
Old Jul 25, 2002 | 03:36 AM
JAWS 021's Avatar
what about the walbro?
You can try that man... Im not sure of the differences between fuel pumps in the NEW betas tongue.gif wink and the old non gt cam bastards
Im pretty sure walbro has one
Let me do some quick research...
Old Jul 25, 2002 | 03:42 AM
JAWS 021's Avatar
http://www.teamsr.org/cgi-bin/ultimatebb.c...c;f=16;t=001167
http://www.teamsr.org/cgi-bin/ultimatebb.c...c&f=16&t=001164
sorry man this is the best that i found frown
Old Jul 25, 2002 | 03:45 AM
Curtas's Avatar
SCCA,
do the new betas trim the fuel pump with voltage regulation? In a returnless system, the pressure will probably be fairly constant for most of the operating conditions. Returning fuel pumps are more about flow rate, returnless pumps are more about pressure. Although I wouldn't be surprised if Hyundai used the same fuel pump. sad.gif
I'll dig around hmaservice and see what I can come up with.
ac
Old Jul 25, 2002 | 04:03 AM
JAWS 021's Avatar
Curtas:
thats what im thinking
frown
Old Jul 25, 2002 | 04:18 AM
Jmontigny's Avatar
Vehicle: 02 Elantra
The 01-02 elantra and the 03 tib use the same pump setup. Here is the interesting part.
There is a fuel pump, assist pump?, and a fuel pressure regulator all located in the tank along with your fuel filter. We have yet to do one but it appears you can get access from under the back seat cushion.
Old Jul 25, 2002 | 07:15 AM
Curtas's Avatar
It almost sounds like the returnless fuel system is just like the return fuel system, except that the regulator, pumping, and bypass all happen right at the tank. I'm wondering if there is some sort of electrical regulation done with the booster pump to compensate for higher loading.
I'd like to see the diagram and wiring, but have been too busy today to dig around HMA.
Seems the car engineers are finding new and exciting ways to make our upgrading more difficult.
good luck,
ac
Old Jul 25, 2002 | 12:04 PM
Jmontigny's Avatar
Vehicle: 02 Elantra
When I get to work tomorrow I will look at the assist pump closer. Maybe I will even order one just to see what the heck it actually is. I have an annual return I am doing in August I'll just return it after I look at it.
