Fuel pump replacement
I ordered the pump asm which has everything in it, pump, regulator, assist pump and filters. It will be here monday. I let you know what exactly is in there when I get them. I did however notice the 01-02 elantra is the same as the 03 tib 4cyl, The 03 6cyl is using a different part.
Guest
Posts: n/a
The actual make and model of each of the pumps. This way I can cross check it with other manufactures. Also take a look at how its regualting pressure, is it voltage to the pump or normally through a mechanical regulator, or the ecu through ther regulator etc... This way If I cant find a direct replacement for the pumps I can figure out whether or not I will need a dead head regulator for an inline pump.
