Fuel pump replacement
Old Jul 31, 2002 | 04:48 AM
  #21
Jmontigny's Avatar
Vehicle: 02 Elantra
Ok I looked at the service book for the 4cyl and 6cyl. The regulator in the tank on the 4cyl is 350kpa the V6 is 300kpa. So I believe you will see no benefit from using V6 stuff. There is a Pressure regulator similar to the ones mounted to the fuel rail, this one mounts on the filter asm. The regulator has a stamp of FPR801 XFL that is it. The pump looks like a standard pump it has no markings at all other than the hyundai logo, hd inside a circle and xff stamped into the plastic top section.
