Weight Reduction
yah that would totally be a drag racing only mod and im sure the drag from the interior would take away from the benefits of the weight loss.
got a new one today.......
i was changing my intake set up (something i do pretty often) and had a little something in the way.
on the tran mount that bolts to the drivers side, theres a arm that originally held up your stock air box. well, obviousely most of us have no use for this. and at the time was in my way. so u busted out my die grinder, and in less then 3 minutes, no more bracket. tongue.gif
now keep in mind it doesnt weigh alot, but every little bit counts.
and also..... your VERY close to the clutch line, and brake lines. if you dont have a steady hand, i wouldnt try this.
