Weight Reduction
Old Apr 10, 2007 | 06:28 AM
  #91
JonGTR's Avatar
I already posted it. I removed mine a while back.
<div class='quotetop'>QUOTE </div><div class='quotemain'>Remove metal plate in the glove box cover - 3.0lbs / 0.00lbs</div>
Old Jun 4, 2008 | 02:59 PM
  #92
01steve's Avatar
Vehicle: 2000 hyundai tiburon
just as a reference i went to the dump to get rid of my old tv and at the same time i got my car weighed (w/o driver)-...
2,500 lbs (-25 lbs for old tv) from a stock curb weight of 2,633 lbs
here's how i did it-...
removed-
back seats, rear seat belts, rear floor mats, spare tire, jack, spare tire cover, rear seat/hatch cover, hatch floor cover, stock front seats (replaced w/ cheap-o ebay seats), glove box weight, stock flywheel (replaced w/ findanza), stock pulleys (replaced w/ obx), IM brace, exhaust shroud under car, exhaust manifold (replaced w/ headers), liners under engine bay, fog inserts, grills (replaced w/ gutter gaurd), hood (replaced w/ CF), hood latch (replaced w/ hood pins), rims (replaced w/ 15lb oz from lancer, perfect fit!), spark plug cover, upper timing belt cover, cruise control, windshield washer fluid resiviour and motors (nozzels too), shift knob (replaced w/ lighter), shifter (replaced w/ short shifter), various un-neccessary brackets and hardware, antenna-.... may be missing a thing or 2
after reading the "why wheels are more than just tire holders" you'd understand that for every pound you lose off un-sprung rotational mass it's like losing 10 pounds off the chasis-...
and i read some where else that for every 10 lbs off your car-... it's better than 1HP
so with a little math i have the gained an equivelant to around 20HP.
there are still a few items on the list that i am considering to further lighten my car-...
i should also mention that my car isn't as quiet as it used to be-... but slightly better on gas, quicker acceleration, and shorter stopping distances!
i hope this was useful!
Old Jun 4, 2008 | 03:38 PM
  #93
Coal_forge's Avatar
The dash with brackets, ducting, bolts, unnessicary wiring, fan, motor, radio, passanger side blow up doll, and sound absorbant materials.
72lbs.
Old Jun 4, 2008 | 04:17 PM
  #94
^^ Passenger side blow up doll?
Old Jun 4, 2008 | 04:54 PM
  #95
Tibbychick's Avatar
a blow up doll wouldn't weigh that much...just blow it up and stick it in the passenger's seat...
Old Jun 4, 2008 | 06:40 PM
  #96
paperstsoapco's Avatar
how much does that airbag weigh? does anybody know?
Old Jun 5, 2008 | 03:34 AM
  #97
tdonnell's Avatar
The passenger airbag is about 6-10 lbs, driver is 5-7 I would say.
Old Jun 5, 2008 | 04:13 AM
  #98
UrS0NvS's Avatar
Coal_forge...
you probably have one of the most stripped out tibs on this site that i have witnessed. would you know by chance the weight of your car with 1/2 tank of gas?
I read somewheres one time that is how they weigh the curb weight of a car, with only 1/2 tank. could be wrong, its been awhile but i your is like a feather.
throw some montegi trak-lites on there and you would drop i think 28 lbs. of rolling inertia compared to oem stock wheels.
Old Jun 5, 2008 | 08:54 AM
  #99
Tibbychick's Avatar
The driver's side airbag and stock steering wheel are actually quite heavy. I took both out in favor of a lighter Momo steering wheel.
Old Jun 5, 2008 | 09:17 AM
  #100
Bullfrog's Avatar
Vehicle: 2001 Tiburon
Removing an airbag in an airbag equipped car is illegal is it not? Or is that just a scare tactic or just plain BS?
