Prs4, And Prs2 Wiring Chart For The Rd Beta I
ok right now i have it wired up like this:
pin 3 prs is going to pin 16 ecu
pin 15 prs is going to pin 43 ecu
this is how jon has it and it works for him for some reason. Tim can you explian why this isnt working for me? should it work how i have it, or why is it working for jon? if you think it will work i will wire pin 3 from the prs over to pin 4 like you had and then do pin 15 prs to 16 ecu and 16 prs to 43 ecu. just let me know how i can get this thing running
and if somehow you think you can make a harness i would be willing to try it if i can get it running
I could never get it running the way dave has it and the way jon has it posted. As soon as I wired it according to mine it fired right up. I worked on this thing for 2 weeks straight talking with Neil in South Africa to get it running.
Try wiring it the way I posted on page 2 and I almost bet that the car will fire up. I can also make a custom harness if needed.
I still have my PRS harness so that is why I would be able to make you a new harness, but I would need some stuff from you. If your intrested hit me up and I can go over some stuff with you.
Also the harness thing goes for anyone else that is having problems. Just send me a PM and we will workout something.
k i did some rewiring and checking things and i did find an issue with how i had wired it. i will be out working on the car all week probably so i will hook everything up and see if shell run. if i find anything out worth posting i will update. the issue i found was a mistake on my part.
