Prs4, And Prs2 Wiring Chart For The Rd Beta I
Old Jan 30, 2007 | 01:29 PM
  #101
on the laptop? i dont think so
Old Jan 30, 2007 | 01:31 PM
  #102
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
if your not getting a pluse then your crank is not wired correctly.
Old Jan 30, 2007 | 01:34 PM
  #103
i will double check that again. crank signal a and b are the same wire. they get spliced together up higher in the wiring off the ecu. i should have pin 3 and pin 15 off the prs to those wires, correct? or do i have something switched? when i get out there next im going to list exactly how i have everything
Old Jan 30, 2007 | 01:36 PM
  #104
No they are separate shielded wires, I will look at the colors and tell you exactly where they go on the prs.
Old Jan 30, 2007 | 01:41 PM
  #105
ok thanks. i was kind of leaning towards something like that but i was sure i had it all right
Old Jan 30, 2007 | 01:43 PM
  #106
It is easy to get it mixed up, trust me I had mine apart several times to check and recheck and recheck again. The Haltech on the other hand fired up first go. I contribute that to all the wiring I had done with the prs.
I have also tossed around the idea of making harness for these that would be a P-n-P deal.
Old Jan 30, 2007 | 01:52 PM
  #107
that would be nice a few months ago before i hacked everything up trying to rewire everything. i could still get it all back together im sure. ill just have to keep trying things i guess. let me know if you find out about those wires or whatever
Old Jan 30, 2007 | 01:57 PM
  #108
I will as soon as I can get to look at it.
Old Jan 30, 2007 | 02:03 PM
  #109
awesome thanks tim
Old Feb 1, 2007 | 08:43 AM
  #110
Ok I have been pouring over different wiring diagrams and it seems the crank colors have changed through out the years. So you will need to look and see what the orignal color of pin 16 on the ECU was that will goto pin 15 on the PRS, and pin 43 originally on the ECU will need to goto pin 16 on the PRS.
