Prs4, And Prs2 Wiring Chart For The Rd Beta I
Old Jan 9, 2007 | 12:50 PM
  #91
I will check it. Havent thought about that really and I will be mad if I find out theres no power.
hey tim, thanks for putting me in a bad mood. i had a blown fuse. im replacing it right now and maybe ill see some injector pulse. i hope so. will report back
Old Jan 9, 2007 | 01:04 PM
  #92
lol, it's always the most simple things that get overlooked.
like me taking off my god damn door panel 5 times to try and fix my stupid power windows, when i realized it was just the window lock button.
Old Jan 9, 2007 | 01:05 PM
  #93
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
That is the main issue I have seen on the units.
Old Jan 9, 2007 | 01:09 PM
  #94
ok well i fixed the fuse and for some reason its still not getting power. im going to go over it tomorrow. there must be a short to ground somewhere not letting me get power
Old Jan 9, 2007 | 01:10 PM
  #95
if so then you will probably have another busted fuse.
Old Jan 11, 2007 | 03:54 PM
  #96
red97tib's Avatar
Vehicle: 1997/Hyundai/Tiburon
If it is blowing fuses more than once then you need to check the problem of why it is blowing fuses. I had mine hooked to the chassis and not the battery and it had power and did everything but read my crank. So I tried hooking it to the battery and it did same thing. I could never figure why mine would read the crank so I had to go back to stock because my Tib is my daily driver.
Old Jan 11, 2007 | 09:42 PM
  #97
i know why its blowing fuses. theres obviously an open in the wire somewhere. im going to re-run a wire tomorrow. hopefully it will work
Old Jan 27, 2007 | 12:17 PM
  #98
got out there today finally and ran a new wire from battery to the prs. still no injector pulse. i cant imagine whats wrong. everything is soldered and hooked up perfectly, to the correct wires. i think its jons map that im using but i dont even remember. i can get the prs to go online and communicate with the laptop but still no damn injectors. im stuck. jon or tim if you have any input let me know. jon, try sending me that map again if you can. i want this thing running so bad
Old Jan 30, 2007 | 01:24 PM
  #99
bump. i see some prs guys on
Old Jan 30, 2007 | 01:27 PM
  #100
Okay when your cranking the car are you seeing rpm's?
