DIY: The "Big 3" wire upgrade
Old Aug 3, 2005 | 11:55 AM
  #61
auburnfan's Avatar
I am about to do this to my Tibby this weekend and want to make sure that I have this correct. So whoever replies to my post just say yes or no if I have it correct or not.
1. Replace ground wire from Neg on battery just the way that it sits
2. Put a new ground from engine to grounding point on chasis
3. ADD a new power wire from positive side of battery to ALT with a inline fuse of 100 or a circuit breaker at 100 and leave original positive to ALT connected.
Sorry but I wanted to make sure that I am doing all of this correctly before I begin.
Old Aug 4, 2005 | 12:06 AM
  #62
fonseca's Avatar
That sounds fine, except for the circuit breaker part.
You could include a step 4: add a negative battery terminal or distribution block with multiple outputs and ground several locations instead of just one.
Old Aug 4, 2005 | 06:06 AM
  #63
Mad_john's Avatar
fing02.gif did it and no problem, go so far.. Thanks brother's
Old Aug 4, 2005 | 06:25 AM
  #64
auburnfan's Avatar
Thanks guys working on it this or next weekend.
Old May 2, 2007 | 08:38 PM
  #65
good luck
Old May 2, 2007 | 08:50 PM
  #66
um...
  #67
lol DTN he needed good luck a year and a half ago.
Old Apr 22, 2008 | 04:14 PM
  #68
StrikeEagle's Avatar
Pics down here too, any chance of retrieving them? I'm mainly interested in seeing how the wires are routed.
Old Apr 22, 2008 | 04:33 PM
  #69
Tib001's Avatar
Since you brought this back up.
There was discussion of removing the factory wire to the alt or not and adding a fuse to the new wire.
Was there ever a final decision on this as to what works best?
Old Apr 22, 2008 | 06:27 PM
  #70
Ive got mine re-wired without an issue.
