Oil Pressure Mishap
Old Jun 7, 2004 | 11:30 AM
javageek's Avatar
Last night my wife and I went to the mall 30 minutes away. Right when we got there I smelled oil burning. I looked at my OP gauge and it was flickering at 0. Pull into the parking lot, pop my hood and see the transmitter dangling. The brass fitting they provide you with snapped off. The only thing I can think is that it was the vibration that finally broke it. I have been over there all morning trying to get the remainder of the fitting out with no luck. So I went with my last resort which was goop some JB weld in and around the hole. I need to go back in an hour to pick it up.
Old Jun 7, 2004 | 12:46 PM
don't buy auto zone gauges :? sorry to hear that
Old Jun 7, 2004 | 03:11 PM
javageek's Avatar
Well, the JB weld didn't work. I may just need to put more around the bottom. I had to tow my car here from Destin, which is about 20-25 miles. :evilguy: I am probably going to go to Sears and buy one of the power extractor bits and use that to get it out, should work.
Old Jun 7, 2004 | 03:58 PM
Voiddweller's Avatar
That's what I would do or use a reverse tap bit to get it out.
....totally not to be off the subject or hijack but do you need another gauge to replace that? We are getting close on that GB.
nyne's Avatar
do you happen to have a diy for that gauge install?
actually.. where is the stock sending unit...?that may be all i need.
Old Jun 7, 2004 | 04:09 PM
javageek's Avatar
<div class='quotetop'>QUOTE (Voiddweller)</div><div class='quotemain'>That's what I would do or use a reverse tap bit to get it out.
....totally not to be off the subject or hijack but do you need another gauge to replace that? We are getting close on that GB.</div>
Maybe, I will have to see if I can get this out.
Old Jun 7, 2004 | 05:05 PM
this is why I bought autometer.. An easy out might be what you need.. I remember using one on my old beetle..
Old Jun 7, 2004 | 05:13 PM
javageek's Avatar
I tried an easy out and it wasn't working. It might be because I didn't drill into it first, I just used the hole that was there. They made the fittings out of brass for some reason.
