Atelier HP
Sponsor:   Atelier HP
If you can think about it, they can make it for your Hyundai!
http://www.atelierhp.com/ = French (Canada)
http://www.atelierhp.com = English
Push Clutch Conversion
Old Jun 4, 2009 | 01:14 PM
  #31
just to give a heads up buddy to help you out...site staff will not toterlate underground drag race
Old Jun 4, 2009 | 01:21 PM
  #32
In Singapore that may be acceptable thats why I havent said anything in any of the threads or the video posted.
Old Jun 5, 2009 | 12:13 AM
  #33
Denisst99's Avatar
just to keep you updated
new flywheel received, clutch kit on its way
crank is in the block, should do the rest of the engine vert soon, once i'm done with our TAD dragster
BTW Jsarr, are you sure of your turbo? those numbers seam quite high for a GT3071r
Old Jun 5, 2009 | 04:26 AM
  #34
kimchi's Avatar
Vehicle: 2006/hyundai/tiburon
ya, in the beginning i too did not believe the numbers, even my tuner doesn't. The GT3071R is running above its efficiency range base on my plot. But i think the meth. injection, sub-injectors n race fuel help to cool down the charge air making it possible to gain power even running off efficiency. SFR is using the same turbo but with a 4' inlet, cams n making 480whp @ 30psi which is abt 552bhp. I running 32psi with meth n Q16+ making only 606bhp, nothing is impossible.
Really need your help to convert into push style clutch. Right now i couldnt flatshift above 25psi. The valeo extreme simply cant hold the torque.
Old Jun 5, 2009 | 08:17 AM
  #35
Denisst, let me know when the install kit can be purchased. Ready to buy. Thanks
Old Jun 5, 2009 | 06:49 PM
  #36
kimchi's Avatar
<div class='quotetop'>QUOTE (Ericy321 @ Jun 5 2009, 09:17 AM) <{POST_SNAPBACK}></div><div class='quotemain'>Denisst, let me know when the install kit can be purchased. Ready to buy. Thanks</div>
Count me in too...........remember to drop me a pm.
Old Jun 5, 2009 | 08:34 PM
  #37
tanc's Avatar
Vehicle: 1997 Tiburon
Jsar, please don't quote the post above yours, 2 posts up is okay tho. Oh btw, thanks for the introduction.
Old Jun 10, 2009 | 11:26 AM
  #38
kimchi's Avatar
Denisst99,
Do you have the part number for the following parts you recommended? On which hyundai car, model and year were these parts from? Thanks!
parts required
lever,
fork,
retainer,
bearing,
2 bushings
James
Old Jun 10, 2009 | 12:05 PM
  #39
Yes, he does, but no, he won't give it out.
He sells it as a kit.
Old Jun 10, 2009 | 12:20 PM
  #40
kimchi's Avatar
Ya, I dont mind buying the kit from him, how fast can he deliver to me? Also I need to know which push clutch is direct bolt on to the it.
