DIY Listing - RD/RD2 Tiburon & Elantra and BETA Engine
Old Jul 23, 2004 | 10:45 AM
Default DIY Listing
If you think a DIY is worthy of addition to the list, PM a moderator. We know some links are bad. We're working on it.
To keep folks from having to look around like crazy to find applicable DIY's, here is a complete list of the available DIY's here divided by section.
To post a DIY, please have all information available...
1. Where to get the product and price.
2. Tools needed and sizes of tools.
3. Sizes of wires, # of connectors, ect...
4. Favorite Beer used during installation.
5. Help needed or what needs to be done professionally for safety sake.
6. Most important, PICTURES!!!
7. Do not post just links to a DIY elsewhere online. Please post the actual DIY writeup here at HyundAftermarket, at least we will have the directions if the page ever goes down.
If your DIY is put up and is missing any of these, you may not get added to the list. Also, DIY's from other sites will not get added to this list as links and pictures change and get deleted and we don't want to police this. If you need to copy and paste a whole page or 2, do it, just give proper credit to the proper folks.
Any questions or comments, PM a moderator!
* ~ It should be noted that there are two main sections of the approved listing, one section with DIYs for Modifications you can do to your vehicle, and another that contains DIYs on maintaning your vehicle ~ *
MODIFICATIONS
GENERAL
Weight Reduction - JonGTR
ENGINE & TRANSMISSION
1.8L Cam Install - UltraTibby
Air/Fuel Meter DIY - Alz99
Connecting Auto Overdrive Button on Aftermarket Shift Knob - Djnevamind
Auto to Manual Swap (Transmission Conversion) - loneshark
BBTB Install & Throttle Body Coolant Bypass Mod (FREE!) - REDZMAN
Beta II Engine in an RD, Engine Swap thread - Optimoprime
Clutch Slave Cylinder Restrictor Removal Mod - WytchDctr
Transaxle Shifter Arm Slop Removal - kupsjon (pictures are dead)
Install Your Own Header - andyengineer (pictures are missing)
Install an Oddessey pc 680 Battery - brian01tib
Outlaw Engineering Phenolic Spacer Install - RED ZMAN (Pictures are missing)
Pivot Raizin Voltage Stabilizer, And Grounding System -RED ZMAN
Stock Intake Resonator Removal DIY - REDZMAN
"Rev.A" Evap Cannister Relocation, In the Engine Bay - rd1tib
RSide Advanced S. Shifter DIY Install - RED ZMAN
RSide Advanced SHORTER Shifter DIY - RED ZMAN
Ark Short shifter DIY - BlizagaXx
SAFC Wiring - REDZMAN
SAFC Wiring -Tak82
SAFC2 Wiring and Setup - javageek
Short Intake DIY - Ruffedge
(missing images)
Starter Button Install - spiceflow
Strut Bar Install Acceleration Sensor Replacement - RED ZMAN
The "Big 3" Wire Upgrade - spiceflow (pictures are missing)
Underdrive Pulley Installation - Alex01tib
Valve/Spark Plug Cover Painting - RED ZMAN (Posted by Canadianshark74) (pictures are missing)
POWER ADDERS/EXTREME MODS
Convert to Push Style Clutch, holds more power than stock pull style will take - Mad john (photos are gone again)
(kit available from Atelier HP)
Can also be done other ways . . . VERY advanced DIY
Emanage/emanage Ultimate Ignition Fix, DIY - t4turbotiburon (pictures are missing)
Fuel Pump Upgrade - SpeedFactor
Intercooler Pipe Pressure Tester - Supercow (pictures are missing)
Nitrous Oxide Kit Install (ZEX) - DTN
Perfect Power Smt-6 Wiring Diagrams Guide, Wiring it from basic to advanced - Jay-M
Prs4, And Prs2 Wiring Chart For The Rd Beta I - JonGTR
Push To Pull Clutch Conversion - t4turbotiburon
Megasquirt Ecu - funkypc
BRAKES, WHEELS, TIRES, SUSPENSION
Center/floor Stabalizer Bar - tibbytib (DIY is missing!)
Duplicolor Wheel Paint - phorq
4 lugs to 5 lug Swap (with Hyundai parts) - Red
INTERIOR & ICE
Rd1 to Rd2 Dash Conversion - fury (pictures are broken! )
2 Seater Conversion (rear seat delete) - SplinterCeL
Add-On Heated Seats - AccentAE86
Auto-Dimming Mirror Install - 01tibby
Dancing LEDs (light up your car to music) - DTN
Door Handle LED Mod - AllBlackTibby
Gauge Face DIY / Dash Removal - RED ZMAN
Interior HALOZ Install - mrpsxplyr (photos are missing)
LEDs - A Quick Guide - Pringles
LED Amps & Caps Rear Panel Box - Mr_Hyde_NT (photos are missing)
LED Glow Needle Mod (for dash gauges) - tibby01
Pix For Leds In Heater And Tibby01's Switch Mod - DrivingTibNaked & Tibby01
Installing Power Door Locks - solo-baric
Racing Seat Fitting - Pandy
Rd2 Hvac Knobs In Rd1 Dash - Tibbychick
Silent Wirelooms DIY - DTN
Starter Button (Version 2) - TheFuzz7532
Steering Wheel Removal & Aftermarket Wheel Installation DIY - Alex01tib
Trunk Popper - fonseca (images are missing)
Trunk Z3 Light Mod DIY - REDZMAN
Vent Angel Eyes(How to make) - firebug21
Window and Sunroof Relay - REDZMAN
EXTERIOR
HID headlight Installation - RED ZMAN
Angel Eyes Install - Blacktibs
Clear Corners DIY - SOCKS
Corner Parking Lights Removal - mrpsxplyr
Full Angel Eyes install/Bumper Removal/Wiring - Joshuwa
Halo HID Headlight Setup - majiktib
License plate LED lights - Phorq
Mesh Grills - Joshuwa
Painted Headlight Bezel DIY - SOCKS
Rear Liscense Plate LEDs - Mr_Hyde_NT
Replacing Lenses With K-spec Smoked Lenses - tanc
Tinted/clear Tails DIY - Szilvertib
Volvo V40 Washer Nozzle DIY - gammelleiche
Washer Fluid Spray Nozzle Relocation - 01tibby
MAINTENENCE/REFERENCE
GENERAL
How to Clean Your Car I - DTN
How to Clean Your Car II - DTN
How to Jack Up Your Car (Jacking/Lifting Points) - DTN
Headlight Aiming Adjustment - Omega
RD1 & RD2 Parts Lists (Parts Manual) - RED ZMAN
VIN Decoder DIY - DTN
Webtech download - MKE
Rebuild Your Alternator - Stocker
Available Firewall Passageway - tibby01
Clean Your PCV Oil Drain - DTN
Fenderwell/ Firewall Wire Passageway - UrS0NvS
Fuel Filter DIY - REDZMAN
Intake Manifold Install - loneshark
(missing images)
Resetting Your ECU - Canadianshark74
Test Your Fuel Pump - REDZMAN
TPS Manufacturer Checking DIY - REDZMAN
(Visual differences, flaky Dae Sung vs. reliable Kefico)
Rear Sway Bar Removal/Replacement - Stocker
Changing Struts - DTN
Quick & Easy Rim Restore - Regit
Struts and Springs Replacement - tibbytib
Wheel Stud Replacement - 01tibby
Captive Hub / Rotor Swap - REDZMAN
(convert from captive rotors to non-captive)
Remove/Replace Power Steering Pressure Hose - Stocker
INTERIOR
Get Rid of Window Rattle - tibby01
Quick Fix for Faded Sunroof Liners - 01tibby
Rear View Mirror Rattle/Vibration Fix - Tibwrcsbj
Repair Intermittent Heater Switch - DTN
EXTERIOR
Cleaning Headlights, ...w/ McGuire's - Patreezy (images are gone)
Modify Headlights for Easy Headlight Aiming - 01tibby
Fog Light Lense Re-Surfacing - tibbytib (pictures are gone)
RD2 Front Bumper Removal - phorq
Side-View Mirror Rattle Fix - 01tibby
