Intake Manifold Install Diy
Old Jun 10, 2005 | 12:10 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
this is copied from an online vehicle parts manual, its not my DIY, although Ill try and adds pics of my AIR RAM install when I do it.
from what Ive searched, you will need some new vaccum hoses, cuz the stock ones are too short. Other than that, if you want you can buy a phenolic spacer for the manifold to prevent heat transfer, but in all seriousness, "underhood" heat transfer will heat that manifold up just as much (if its not ceramic coated), so do what you wish. Enjoy and good luck !! but who needs luck when you got skill !!
<u>PART NUMBER and LIST PRICE</u>
Manifold 2831023005 $318.53
<u>TORQUE SPECS</u>
Throttle Body 15 - 20 Nm
Intake Manifold To Cylinder Head Nuts And Bolts 15 - 20 Nm
Intake Manifold Stay To Cylinder Block Bolts 23 - 30 Nm
Intake Manifold Nuts 18 - 25 Nm
<u>REMOVAL</u>
1. Remove the idle speed actuator.
2. Remove the intake air hose connected to the throttle body.
3. Remove the accelerator cable.
4. Remove the PCV hose and brake booster vacuum hoses.
5. Disconnect the vacuum hose connections.
6. Disconnect the high pressure fuel hose connection after relieving pressure in the fuel pipe line to prevent fuel overflow.
7. Remove the surge tank stay.
8. Remove the surge tank assembly and gasket.
9. Disconnect the fuel injector harness connector.
10. Remove the delivery pipe with the fuel injectors and pressure regulator attached. CAUTION: Be careful not to drop the injectors when removing the delivery pipe.
11. Remove the insulator from the intake manifold and disconnect the heater hose.
12. Remove the intake manifold.
<u>INSTALL</u>
1. Replace the intake manifold gasket and install the intake manifold.
2. Install the insulator to the intake manifold and connect the heater hose. CAUTION: Be careful not to drop the injectors when removing the delivery pipe.
3. Ensure that insulators are correctly inserted into the delivery pipe hole.
4. Install the delivery pipe with the fuel injectors and pressure regulator attached.
5. Connect the fuel injector harness connector.
6. Install the intake manifold stay.
7. Connect the high pressure fuel hose connection.
8. Connect the vacuum hose connections.
9. Install the PCV hose and brake booster vacuum hose.
10. Install the intake air hose to the throttle body.
11. Install the accelerator cable.
12. Install the idle speed actuator.
Old Jun 10, 2005 | 12:43 PM
mb1604's Avatar
AWESOME im putting my airram in next week or week after, big help!
Old Jun 10, 2005 | 07:18 PM
<div class='quotetop'>QUOTE (loneshark @ Jun 10 2005, 12:10 PM)</div><div class='quotemain'>if you want you can buy a phenolic spacer for the manifold to prevent heat transfer, but in all seriousness, "underhood" heat transfer will heat that manifold up just as much (if its not ceramic coated), so do what you wish.<div align='right'><{POST_SNAPBACK}></div></div>
No, it won't, it's been proven. Check the post on Hondata.com's heatsheild gasket. Intake temps up to 70 to 100 degrees lower.
Ceramic coating will help even more.
Old Jun 10, 2005 | 07:28 PM
turbotiburon's Avatar
Vehicle: 2001 tiburon/2000 tiburon
True my man.. and even check out outlaws site.. they even have more info I do believe... man your stuck on that hondadata..!
Old Jun 10, 2005 | 09:33 PM
Tiburonmoo's Avatar
I'm sure he just brings up Hondata because it's an established, well known and reputable company for everyone to reference.
Old Jun 10, 2005 | 11:48 PM
<div class='quotetop'>QUOTE (proturbotiburon @ Jun 10 2005, 07:28 PM)</div><div class='quotemain'>True my man.. and even check out outlaws site.. they even have more info I do believe... man your stuck on that hondadata..!
No no, I just didn't look hard thru OUtlaws site. I'll go check it out.
EDIT
I just went and checked out their info. MUCH better prepared and informative than Hondata.com
This is off topic, so I'll post stuff about it tomorrow.
http://www.outlawengineering.com/techframe.html
Old Mar 25, 2008 | 07:27 PM
warnarf's Avatar
Pics have been removed from photobucket. Report button says I don't have permission to use that feature.
