DIY Listing
If you think a DIY is worthy of addition to the list, PM a moderator. We know some links are bad. We're working on it.
To keep folks from having to look around like crazy to find applicable DIY's, here is a complete list of the available DIY's here divided by section. To post a DIY, please have all information available... 1. Where to get the product and price. 2. Tools needed and sizes of tools. 3. Sizes of wires, # of connectors, ect... 4. Favorite Beer used during installation. ;) 5. Help needed or what needs to be done professionally for safety sake. 6. Most important, PICTURES!!! 7. Do not post just links to a DIY elsewhere online. Please post the actual DIY writeup here at HyundAftermarket, at least we will have the directions if the page ever goes down. If your DIY is put up and is missing any of these, you may not get added to the list. Also, DIY's from other sites will not get added to this list as links and pictures change and get deleted and we don't want to police this. If you need to copy and paste a whole page or 2, do it, just give proper credit to the proper folks. Any questions or comments, PM a moderator! * ~ It should be noted that there are two main sections of the approved listing, one section with DIYs for Modifications you can do to your vehicle, and another that contains DIYs on maintaning your vehicle ~ * MODIFICATIONS GENERAL Weight Reduction - JonGTR ENGINE & TRANSMISSION 1.8L Cam Install - UltraTibby Air/Fuel Meter DIY - Alz99 Connecting Auto Overdrive Button on Aftermarket Shift Knob - Djnevamind Auto to Manual Swap (Transmission Conversion) - loneshark BBTB Install & Throttle Body Coolant Bypass Mod (FREE!) - REDZMAN Beta II Engine in an RD, Engine Swap thread - Optimoprime Clutch Slave Cylinder Restrictor Removal Mod - WytchDctr Transaxle Shifter Arm Slop Removal - kupsjon (pictures are dead) Install Your Own Header - andyengineer (pictures are missing) Install an Oddessey pc 680 Battery - brian01tib Outlaw Engineering Phenolic Spacer Install - RED ZMAN (Pictures are missing) Pivot Raizin Voltage Stabilizer, And Grounding System -RED ZMAN Stock Intake Resonator Removal DIY - REDZMAN "Rev.A" Evap Cannister Relocation, In the Engine Bay - rd1tib RSide Advanced S. Shifter DIY Install - RED ZMAN RSide Advanced SHORTER Shifter DIY - RED ZMAN Ark Short shifter DIY - BlizagaXx SAFC Wiring - REDZMAN SAFC Wiring -Tak82 SAFC2 Wiring and Setup - javageek Short Intake DIY - Ruffedge (missing images) Starter Button Install - spiceflow Strut Bar Install Acceleration Sensor Replacement - RED ZMAN The "Big 3" Wire Upgrade - spiceflow (pictures are missing) Underdrive Pulley Installation - Alex01tib Valve/Spark Plug Cover Painting - RED ZMAN (Posted by Canadianshark74) (pictures are missing) POWER ADDERS/EXTREME MODS Convert to Push Style Clutch, holds more power than stock pull style will take - Mad john (photos are gone again) (kit available from Atelier HP) Can also be done other ways . . . VERY advanced DIY Emanage/emanage Ultimate Ignition Fix, DIY - t4turbotiburon (pictures are missing) Fuel Pump Upgrade - SpeedFactor Intercooler Pipe Pressure Tester - Supercow (pictures are missing) Nitrous Oxide Kit Install (ZEX) - DTN Perfect Power Smt-6 Wiring Diagrams Guide, Wiring it from basic to advanced - Jay-M Prs4, And Prs2 Wiring Chart For The Rd Beta I - JonGTR Push To Pull Clutch Conversion - t4turbotiburon Megasquirt Ecu - funkypc BRAKES, WHEELS, TIRES, SUSPENSION Center/floor Stabalizer Bar - tibbytib (DIY is missing!) Duplicolor Wheel Paint - phorq 4 lugs to 5 lug Swap (with Hyundai parts) - Red INTERIOR & ICE Rd1 to Rd2 Dash Conversion - fury (pictures are broken! ) 2 Seater Conversion (rear seat delete) - SplinterCeL Add-On Heated Seats - AccentAE86 Auto-Dimming Mirror Install - 01tibby Dancing LEDs (light up your car to music) - DTN Door Handle LED Mod - AllBlackTibby Gauge Face DIY / Dash Removal - RED ZMAN Interior HALOZ Install - mrpsxplyr (photos are missing) LEDs - A Quick Guide - Pringles LED Amps & Caps Rear Panel Box - Mr_Hyde_NT (photos are missing) LED Glow Needle Mod (for dash gauges) - tibby01 Pix For Leds In Heater And Tibby01's Switch Mod - DrivingTibNaked & Tibby01 Installing Power Door Locks - solo-baric Racing Seat Fitting - Pandy Rd2 Hvac Knobs In Rd1 Dash - Tibbychick Silent Wirelooms DIY - DTN Starter Button (Version 2) - TheFuzz7532 Steering Wheel Removal & Aftermarket Wheel Installation DIY - Alex01tib Trunk Popper - fonseca (images are missing) Trunk Z3 Light Mod DIY - REDZMAN Vent Angel Eyes(How to make) - firebug21 Window and Sunroof Relay - REDZMAN EXTERIOR HID headlight Installation - RED ZMAN Angel Eyes Install - Blacktibs Clear Corners DIY - SOCKS Corner Parking Lights Removal - mrpsxplyr Full Angel Eyes install/Bumper Removal/Wiring - Joshuwa Halo HID Headlight Setup - majiktib License plate LED lights - Phorq Mesh Grills - Joshuwa Painted Headlight Bezel DIY - SOCKS Rear Liscense Plate LEDs - Mr_Hyde_NT Replacing Lenses With K-spec Smoked Lenses - tanc Tinted/clear Tails DIY - Szilvertib Volvo V40 Washer Nozzle DIY - gammelleiche Washer Fluid Spray Nozzle Relocation - 01tibby MAINTENENCE/REFERENCE GENERAL How to Clean Your Car I - DTN How to Clean Your Car II - DTN How to Jack Up Your Car (Jacking/Lifting Points) - DTN Headlight Aiming Adjustment - Omega RD1 & RD2 Parts Lists (Parts Manual) - RED ZMAN VIN Decoder DIY - DTN Webtech download - MKE ENGINE & TRANSMISSION Rebuild Your Alternator - Stocker Available Firewall Passageway - tibby01 Clean Your PCV Oil Drain - DTN Fenderwell/ Firewall Wire Passageway - UrS0NvS Fuel Filter DIY - REDZMAN Intake Manifold Install - loneshark (missing images) Resetting Your ECU - Canadianshark74 Test Your Fuel Pump - REDZMAN TPS Manufacturer Checking DIY - REDZMAN (Visual differences, flaky Dae Sung vs. reliable Kefico) BRAKES, WHEELS, TIRES, SUSPENSION Rear Sway Bar Removal/Replacement - Stocker Changing Struts - DTN Quick & Easy Rim Restore - Regit Struts and Springs Replacement - tibbytib Wheel Stud Replacement - 01tibby Captive Hub / Rotor Swap - REDZMAN (convert from captive rotors to non-captive) Remove/Replace Power Steering Pressure Hose - Stocker INTERIOR Get Rid of Window Rattle - tibby01 Quick Fix for Faded Sunroof Liners - 01tibby Rear View Mirror Rattle/Vibration Fix - Tibwrcsbj Repair Intermittent Heater Switch - DTN EXTERIOR Cleaning Headlights, ...w/ McGuire's - Patreezy (images are gone) Modify Headlights for Easy Headlight Aiming - 01tibby Fog Light Lense Re-Surfacing - tibbytib (pictures are gone) RD2 Front Bumper Removal - phorq Side-View Mirror Rattle Fix - 01tibby |
