Vendor's Booth: General
3 Way Windshield Washer Nozzle
Old Jan 14, 2008 | 05:59 PM
Mine have been yellow and black, and all fit.
LOL
Did you email?
Old Jan 14, 2008 | 06:03 PM
badshah's Avatar
Vehicle: 1997 Hyundai Tiburon
Yep
Maybe European models are different?
Old Jan 25, 2008 | 09:45 PM
Blank_00Tib's Avatar
Got mine in today, we'll see how they fit tomorrow morning, mine have ellow on the bottoms just fyi if it means anything.
Old Jan 26, 2008 | 12:25 AM
paoki's Avatar
I have them too...they dont fit on the OEM hood...had to open the holes a lot to make them fit...
Same happened to 2 more cars here...When thet are in thought they work fine! laugh.gif
Old Jan 26, 2008 | 08:52 AM
I can't even get my old washer nossels of to see if these fit. Anybody got any advice?
Old Jan 26, 2008 | 02:07 PM
Europeans must have a different set of OEM nozzles on their hoods then, that's all I can think of.
To get the OEM ones off, you pull off the hose, look at it, see the clips that hold it in place, compress them, push it out.
Old Jan 27, 2008 | 10:36 AM
There was no way I could compress those things and get them out man. So I just cut the tabs off with wire snips. And the new ones fit right in. Only problem is they get washer fluid on the hood before they even hit the windshield and they hit the wiper arm but if I raise them anymore they shoot over the roof.
Old Jan 27, 2008 | 10:43 AM
All 4 sets I've put on clipped right out. I had to use some channel locks to do it, but it worked.
As for aiming, use a fine wire or a needle, and put it in the nozzle.
With gentle pressure, move the nozzle, and then remove the needle. Have someone inside the car test it.
May take awhile, but all of mine aim perfectly.
Old Jan 27, 2008 | 01:20 PM
I used a needle when I did it. They aim easily, there's just no sweet spot. It's either over the roof or hitting the wiper arm and it get's on the hood right in front of the nossel no matter what.
Old Jan 28, 2008 | 07:58 PM
Might want to use something longer then, these have more than just 2 positions, hood or roof.
BTW, don't forget, you want them rather low on the windshield, otherwise you'll miss most of it when you use them at speed.
