Vendor's Booth: General
3 Way Windshield Washer Nozzle
Old Jan 10, 2008 | 01:46 PM
badshah's Avatar
Vehicle: 1997 Hyundai Tiburon
I just got those for the RD1 fron SFR.
But these don't fit the OEM on my RD1, these are a bit bigger and don't fit in the hole.
What do you suggest me to do to make them fit? Cut a bit off from the sides?
Old Jan 10, 2008 | 03:40 PM
They should fit just fine. I have a set on my RD2, my old RD1 has a set, and my Kia Sorento has a set.
If it's a TIGHT fit, then get a file, and file down the edges of the hole, or the plastic, just a bit.
I've never ever heard of these not fitting anyone.
Old Jan 10, 2008 | 05:42 PM
badshah's Avatar
Ok, I'll try it that way tomorrow.
Maybe the European models are a bit ditterent
Old Jan 10, 2008 | 08:33 PM
Blank_00Tib's Avatar
I was just gonna ask you about these REDZ. Do they work fine or does it spray all the way up to the hood? Mine used to do that but I want new ones now cause mine got wax in em they spray like garbage now...just an excuse to get some new ones also.
Old Jan 11, 2008 | 12:41 AM
definitely dont file the hood openings, the last thing you want is rust. just shave a little off the nozzles if its tight.
this is an awesome mod btw guys, you can adjust the trajectory of each nozzle with a needle stuck into it and aim it wherever you want spray.
may i remind you guys that you may want to look at my cowl nozzle relocation DIY at this time as well(in the diy listing). wink1.gif
Old Jan 11, 2008 | 12:44 AM
I had to file the holes in my CF hood to get them to fit, but they fit the OEM hood fine.
You can file the metal ones, just put a coat of black fingernail polish around the edges when you are done.
Old Jan 11, 2008 | 02:50 PM
badshah's Avatar
Mine just would fit in :s it wasnt even a tight fit
It is about 3-5mm bigger than the holes of the oem nozzles
EDIT-
Ok, I just took the plastic packing where the nozzle was in out of the garbage and doublechecked the numbers, and checked those on the sfr website
they sent me: 98630 2C700
while the one on their website says: 98630 3K500
I think they sent me the wrong one, what should I do? Can they send me a new one or do I need to order them again?
Old Jan 14, 2008 | 01:35 PM
I just ordered a set. Hope they fit perfectly for me.
Old Jan 14, 2008 | 03:49 PM
They should, this is the first time, ever, that someone couldn't fit them. Mine wouldn't fit on my CF hood, so I filed the holes down a bit, and they fit fine.
Part numbers change, and often the same part on different vehciles will have different part numbers, I doubt thats the issue at all.
Again, we've sold hundreds of these, even when I was with Kspec, and they have always fit everything.
Feel free to email jay at seoulfulracing @ yahoo.com to see what he has to say.
BTW, is it the OEM hood? I mean is it the hood that came ON the car or was it replaced in an accident?
Old Jan 14, 2008 | 05:54 PM
badshah's Avatar
Yep, the hood is still OEM.
The nozzles I got had a yellow bottom (the piece that goes into the hood), on the pictures those are black
Maybe I will order new ones
