Will Not Idle....
Old Feb 11, 2007 | 09:18 PM
QUOTE (javageek @ Feb 11 2007, 05:14 PM)
I added fuel with the Haltech and got it to idle fine. Driving around is a little rough. There is no difference in the PVC for the Beta 1 and Beta 2 is there?
Ehh, check your old PVC and see if Viper had it drilled out or not. I think he did.
Old Feb 11, 2007 | 09:45 PM
SuPaDuPa's Avatar
check your evap purge solinoid thats what happend to mine it would barly run
Old Feb 12, 2007 | 04:31 AM
javageek's Avatar
Thanks for the help guys, but I already got it going about four posts ago. lol wink1.gif
Old Feb 12, 2007 | 09:53 AM
JonGTR's Avatar
Yea, you got it running, but you didn't solve the problem. There's a reason why it stopped idling.
If you're running the Haltech and don't have the IAC working, then you're probably idling off the TB screw. In that case, you're gonna have a hard time idling when the weather changes. Your AFR's are gonna keep changing too.
Check to see exactly how you're controlling the idle. Either through the Haltech w/IAC, the stock ECU w/IAC, or the TB screw.
Old Feb 12, 2007 | 02:33 PM
javageek's Avatar
I am pretty sure it is idling off the screw... grrr. My AFR is super rich today.
and my power steering belt keeps squeeling!
Old Feb 12, 2007 | 02:40 PM
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
lmao.gif Welcome to the world of standalone with no AICV.
I usually have to adjust mine a little sitting in the pits everytime I go out, but nothing drastic.
Old Apr 27, 2007 | 12:56 PM
javageek's Avatar
This car is driving me nuts! I am once again having problems leaning out after driving it for awhile. I am thinking it has to do with the alternator not putting out enough to power the injectors. Does that sound right? Also, NOW I am having a problem with it running RICH and dying at idle! Sometimes I wonder what the heck I got myself into and if I would be better off selling this and going back to a near stock tib.... 02.gif
Old Apr 27, 2007 | 02:01 PM
peter_2150's Avatar
Can you get ahold of viper. I am haveing the same leaning out issue at idle to. I went in a bump up the fuel just a little and the 3 lower rpm points. And it helped.
Old Apr 27, 2007 | 02:13 PM
javageek's Avatar
I don't think adjusting the fuel is going to do anything for me. I think it has alot to do with the alternator. I have a new one , maybe I will get it installed tonight. As far as leaning out on idle, isn't there a coolant map as well as a fuel map? Maybe I need to start messing with that since it seems to lean out when the engine is hot.
Old Apr 27, 2007 | 02:49 PM
peter_2150's Avatar
My problem is fuel. I can got her to idle fine. But when I press the gas and let go she dies out =(. It is just a pain to try to adjust the fuel buy myself. BTW what you AFR at. mine is 13.5 at idea 750 rpm.
