Will This FPR Work With Our Cars?
Old Mar 12, 2006 | 11:11 AM
  #21
cbehage's Avatar
Are you talking about the stock return line under the rail being to small or he section of the stock FPR?
Old Mar 12, 2006 | 11:37 AM
  #22
Denisst99's Avatar
the regulator has a restrictor in it..
so with a high flowing fuel pupm (over 200lph) fuel presure control is 2unstable at idle, meaning instead of running 43.5 psi (with vacuum off) you'll run around 55 (vacuum on or off) becasue the regulator doesn,t flow enough to let extra fuel back to thje fuel tank
Old Mar 12, 2006 | 01:42 PM
  #23
JonGTR's Avatar
QUOTE (cbehage @ Mar 12 2006, 12:11 PM)
The section that doesnt get replaced in the B&M's version. The lower half.
Hondas and probably others have the same problem with them.
Old Mar 12, 2006 | 03:27 PM
  #24
LarryMcFly's Avatar
Ok, I understand the problem. I am using the stock pump. I have an n/a setup, a pump that would flow more is no use to me. I see that boosted setup would have a problem.
Old Mar 12, 2006 | 03:42 PM
  #25
supercow's Avatar
your not going to need the 255 till a pretty high level of boost are you? does anyone have an idea at what level that might be an issue?
because you can always use a turbo dsm pump or the 190 walbro and I'm sure people have used them up to about 12-16 psi.
I'm planning on using the vortech fmu with the gsx pump cause it was a cheap, quick solution. btw, does anyone know, should you disconnect the vaccuum to the stock fpr in a situation like that?
edit: btw, i'm not saying getting a 255 isn't a good idea. just for me right now this was an easy first step. everything i'm doing to fuel cost me less than $100, but eventually I'll upgrade to a setup like jon's. (~$300?) with a fuel computer management of some kind, hopefully airborne's ecu
double edit: just did a bit more research, that fpr looks an aweful lot like the one they make for carburated engines. and it's not vacuum relative.
http://www.aeromotiveinc.com/pdetail.php?prod=17
Old Mar 12, 2006 | 06:04 PM
  #26
Denisst99's Avatar
you need to hook up the vacuum line.
that way fuel pressure wil lincrease based on a 1:1 ratio with boost it wil lalos be lowered when vacuum (cruise) is applied
Old Mar 13, 2006 | 12:34 AM
  #27
JonGTR's Avatar
Stock pump is only good til 170whp.
I would not run the stock pump with any boost.
Old Mar 13, 2006 | 05:21 PM
  #28
supercow's Avatar
QUOTE (Denisst99 @ Mar 12 2006, 08:04 PM)
that makes sense, looking back on it, i'm not sure why i questioned it. jon I agree, thats just pushing it a little too far when you can get them so cheap.
