UFB's Turbo and Pistons with the 1.8L
Old Jan 26, 2002 | 07:04 AM
Curtas's Avatar
UFB,
The pre-2000 tiburons in the US came in 1.8L (base) and 2.0L (FX) models. Since the 2000 year, they are all 2.0L
But there are quite a few 1.8's running around here in the States.
If you could look into tuning maps, I'd appreciate it. Another option I'm looking at is getting a 2.0L crank and conrods (the only thing we need to convert to a 2.0L engine, besides the ECU).
I have a datalogger for my car, I could help out by doings some runs and watching ignition timing and injector duty cycle at different rpms and engine loads. That might be a start. . .
ac
Old Jan 29, 2002 | 05:27 AM
Red's Avatar
Red
The turbo kit will definately NOT fit a 1.6L BETA engine.
The 1.6L engines use the 1.8L crank but a completely different piston size. I'm guessing they also use different rods because the block casting is different, so Hyundai has probably modified the block height for a more "compact" configuration to match the de-stroked and de-bored size.
We do know the cams are the same though, which leads me to believe that perhaps the cylinder head port placement (ie intake manifold and exhaust manifold) will be similar enough to bolt on UFB's external components.
There's too many unknowns on the 1.6L engine to be very sure of anything... But I do know the pistons are different.
-Red-
Old Jan 29, 2002 | 06:50 AM
Curtas's Avatar
Hey Red,
What would it take to upgrade the 1.8L to the 2.0?
I was thinking just crank, rods, and ECU? I'm pretty sure the injectors, fuel pump, block, etc are the same; but I'm not sure, so that's why I ask.
ECU would be taken care of in the kit, and if I'm changing the pistons anyway, it seems like replacing the crank might not be too bad of an option.
Or is it so hard and expensive that I should probably just buy a 2.0L long block?
ac
Old Jan 29, 2002 | 07:01 AM
Red's Avatar
Red
The current operating theory is just what you outlined: crank, rods, ECU. I don't have 100% verification on that, but I know that basically everything else (longblock) mechanically and electronically between the two is identical.
If you can get a crank and rods, you could probably "swap" for a 2.0L setup. In fact if you need a stock ECU and can wait a month, I'll have one for sale
-Red-
Old Feb 1, 2002 | 07:20 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
hey red
I have to say that i need a turbo kit for my 1.6. any suggestions?
another thing... DAMN!
Old Feb 3, 2002 | 11:09 AM
Elantra151's Avatar
u have a 1.6 elantra?
i would say start with a cai,bbtb,bim,and a 2.5 cat back for the turbo right guys? smile.gif
Old Feb 3, 2002 | 11:13 AM
Elantra151's Avatar
but my question is whts the difference between the elantra 1.8 engine to the tibby 2.0 inside the engine seeing hows theres no visual difference xcept the larger block?
Old Feb 3, 2002 | 02:22 PM
4doorGL's Avatar
Vehicle: 2009 Hyundai Sonata Limited V6, 2008 Nissan Xterra Off-Road
The 1.8L has a different crankshaft and rods that makes the stroke shorter.
Old Feb 3, 2002 | 07:49 PM
Actually, it was 1999 that they were all 2.0L. Tiburons and Elantras were all 2.0L in 1999 foward.
