Some Supercharger Formula
thanks. the alpine replaces the IM and it comes with its own extended pulley that comes out to where the belts are. i haven't put it on yet so i have no idea where it's going to mount onto but yes it did come with somekind of mount but i'm thinking it's an extension of the stock tibby pulley or something.
goddamn faith, that's going to be a sick custom setup!! good luck!
^right, you have to get new flywheel and all that to bring it up, even upgrade your injectors to bring the boost up. but it's a decent little machine for our litto engines. the problem with it is is it really worth paying for 93 octane gas and hundreds of dollars for computer tuning for it when you can just throw an airram in.
so faith, this one you're getting it a front mount? and is it larger than the alpine?
i will get pics soon.
yeah im gonna run either a m62 or a m90
yours is a m40
and it will be in front so if i wanted i could install a AirRam afterword
and no front mount
water to air intercooler
yours is a m40
and no front mount
Not only will it be bigger, and better mounted, but think about it HKC.
You could use a aftermarket manifold with this...
ugh dammit
my totals are off cuz i forgot i told redz to measure the underdrive crank
so infact with the stock crank i will be runnin more boost
gotta measure the stocker
