Seoulfulracing Turbo Kit
Old Feb 9, 2006 | 06:50 AM
  #21
alright i found out why using 1.8 rods and pistons is a bad idea
with that rod and piston the piston never actually reaches the top of they cylinder so finding TDC when your seting up the timing belt will be a bish
also since it doesnt go all the way up you can accumulate rust at the top of the cylinder plus you can start to build oil and gunk up there which could cause misfiring later on
and finally the reason its not a good idea is the quelch area will be messed up
D i keep tryin to tell you
it would cost you ALOT more to install a new motor cuz yours blew up cuz you didnt do it the right way the first time
Old Feb 9, 2006 | 08:20 AM
  #22
Dmitry's Avatar
Vehicle: Elantra HD / 2007
QUOTE (faithofadragon @ Feb 9 2006, 03:50 PM)
what about head? piston never touches the head and there may build up same crap.
how bad it would be?
Old Feb 9, 2006 | 09:25 AM
  #24
Dmitry's Avatar
motor work is not expensive in Ukraine, I can overhaul whole engine for $300. Or change pistons and all gaskets for $150.
what can be wrong with quelch area?
what is the difference for pistons were their TDC will be? They should not notice it.
Old Feb 11, 2006 | 02:19 PM
  #26
Mahonroy's Avatar
They are using the 1.8 pistons because they are stronger and its basically kind of like a stroker kit right? The guy who is offering this kit has the same setup installed on his car and dynoed at a little over 400hp to the wheels, there is a decent sized thread on elantraxd that has tons of pics of the install process on his car...here it is: http://www.elantraxd.com/forums/showthread...?t=12261&page=1 he has more info and more pics on his website too...
Old Feb 11, 2006 | 02:43 PM
  #27
and while your sending people to outside threads how about you go into your profile and update your location and tib year...if you dont gotta tib put none
Old Feb 11, 2006 | 03:27 PM
  #28
Dmitry's Avatar
j/k
Old Feb 11, 2006 | 08:03 PM
  #29
Mahonroy's Avatar
QUOTE (faithofadragon @ Feb 11 2006, 09:43 PM)
Done!
Old Feb 11, 2006 | 08:04 PM
  #30
thanks!!!
oh and D
