Project Under Way!
vids arent working for me either but thats a worthy project you taken on. the car looks hot and hopefully you will have her running strong here shortly. good luck my man something tells me that sometime before long i'll get to see your tib in person seeing as how your just over in the burg.
I finished most of the small things today. Completed the vacuum lines for the MAP sensor. I am having some weird issue with the turbo box Denis provides. Everything was wired correctly, when the turbo box is not plugged in, and the loop back connector is in place, the car idled fine. After I put the turbo box in and set the commands for a 0-20psi AMP reading, the car would idle, but sound like it wanted to die. I put in the switch setting at 2psi and tried again, and it did the same thing. I checked my fpr and it is set at 40psi idle, but the car would idle great when it was at this before. I'm thinking I may of already fouled plugs or I may be out of fuel. Sgggestions?
i'm quite positive i traced where the problem is coming from,
gonna have some news when everything gets back to normal over here (no electricity)
if you want to do a quick check,
with a multimeter check the voltage you're getting with the engine running,from ground to the turbo box purple wire (wire that is connected to your ecu)
