Pre-turbo
Old Nov 6, 2004 | 09:42 PM
Default Re: Defroster is Broken!
definatly start with better pads... and I would advise against drilled rotors as they tend to crack under heavy use, but slotted work just perfectly.
Old Nov 6, 2004 | 10:51 PM
TiburonWao's Avatar
Default Re: Vibration while in neutral
I recomend that get all the money that you can get before the Turbo ansd save it. As soon as you get the turbo installed, you will have money to buy anything else missing... like Clutch, Pistons, Fuel Pump, Air Ram, BBTB and etc...
Put a Turbo is a little expensive, so you better get all the information needed to know wich Turbo and configuration is the best, and do a "buying list" for the that moment
Old Nov 7, 2004 | 07:05 AM
brian01tib's Avatar
Default Re: GT Tech Front Lip - FINALLY GOT IT!!
Does anybody know which pads and rotors are the best because I have seen so many online.
Old Nov 7, 2004 | 07:24 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: *EBAY Alert* FOR ALL YOU CF LOVERS
There was a GB that is still kinda going on for the rotors, and they have worked well so far with the EBC Greenstuff pads. Run a search on the Brakes, Wheels, Tires Forum and you'll find what you need.
Here is the direct link to the thread on the Greenstuff pads, there is more info in there if you search.
http://www.rdtiburon.com//index.php?name=F...viewtopic&t=651
Old Nov 7, 2004 | 03:39 PM
brian01tib's Avatar
Default Re: *EBAY ALERT!!* Beta Series PHENOLIC SPACER (Intake Man.
QUOTE (Shadowcat)
I am wondering what type of gains will you revice with the 1.8 intake cam on the na VS turbo?
I would also like to know, Thanks
Old Nov 7, 2004 | 09:28 PM
TiburonWao's Avatar
Default Re: Who has a MSD installed in a tibu 2000?
Just remember to get the 1.8 GT Cam.... not the regular....
Old Nov 8, 2004 | 03:34 PM
brian01tib's Avatar
Default Re: Turbo on 200k?
ok
Does anyone know how much the cams will help the preformance
Old Nov 8, 2004 | 03:42 PM
TiburonWao's Avatar
Default Re: 10" sub enclosure type / amp enclosure thingy /comp
5 to 10 HP the GT cam
The High lift and duration CAMS from SHharkracing... they claim +20HP
On Ebay they are those CAMS runing at $400.00 right now
