A Picture Book-my Tib Work-turbo-build
Old Nov 13, 2009 | 11:27 AM
  #21
David Dickson's Avatar
Oh I definitely agree its all in the Tune AND the Tuner. I haven't read any reviews on what the grooves due with boost pressure. I mean how does it affect the flame propagation? Any just because you can run 15psi on stock 10.1:1 pistons does not mean you can run 8psi on 11.1:1 pistons. You are adding a full point to your static compression ratio. Its also all about the quench area and piston shape. The 1.8L piston has a much higher and different dome shape that could cause hot spots in a F/I application.
but as you said, we will see.
Old Nov 13, 2009 | 12:09 PM
  #22
SR Tech's Avatar
Vehicle: 2011 Tuscon
Not that it really matters but our comp is 10.3:1
I personally can't wait to see... I have yet to see anyone sucessful with high comp forced induction
Old Nov 13, 2009 | 02:42 PM
  #23
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
SR how to you determine a compression ratio?
Old Nov 13, 2009 | 06:14 PM
  #24
SR Tech's Avatar
I'm trying to figure out if thats an actual question but either way its easier to just link you here
http://www.csgnetwork.com/compcalc.html
We had tests every week for this is school, so hard remembering everything
Old Nov 14, 2009 | 03:32 PM
  #25
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
most of the day wasted on waiting on an oil pan gasket to arive at advanced, but tonight will be a long night. post pictures later
Old Nov 14, 2009 | 03:38 PM
  #26
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
You might want to just use RTV, I used a gasket and have had small oil leaks.
Old Nov 14, 2009 | 05:20 PM
  #27
RTV would have been best solution
Old Nov 14, 2009 | 09:00 PM
  #28
iheartmyrd's Avatar
i use rtv and the gasket done it a cupple times now on different cars and i have never had a leak.
need anther cutting wheel and ill get more done tomorrow
Old Nov 14, 2009 | 09:07 PM
  #29
all these turbo builds over the winter makes me want too do it...LOL
umm boost
Old Nov 14, 2009 | 09:37 PM
  #30
TibFreak's Avatar
You need a better camera my friend. But seems to be coming along good.
