Ecu Swap Kit - Tibminn's Rd2 Is Successfully Swapped!
dvanderk- sent you a PM. About the autotranny, we can do it, but it's probably not worth the money that it will cost you. I'm confused about your A/F question. I'm actually running pretty rich right now.
TiburonsRule-
Yes, we also do NA ecu reflashes as well. The gains aren't huge numberwise, but you will have an increase of power across the entire RPM range -depending on your setup, which is what REALLY matters. We can retune your ecu with your NA upgrades and raise the max RPM for you. I'll start an ECU reflash topic in the engine & trans forum.
TiburonsRule-
Since the Siemens ECU that we use is in such high demand in Korea, we can only buy it new from the factory. Costs us over $300 USD each. IMHO, it's a pretty good deal for such a great ecu, but anything we can do to offset the costs will help out the RDtib community.
Dude, Faithofadragon goes to the junkers on a weekly basis, we can get you some ECU's bro, just tell us which ones you want.
QUOTE (kikassboy @ Mar 7 2006, 01:22 PM)
lmao.gif Just let me know what you need and hook you up man!
