Details Details
Old Jun 3, 2005 | 02:09 AM
00tibby's Avatar
alright tomorrow i buy my turbo and i want to double check and make sure i have all the parts needed, such as spark plugs(V-Power)
heres the list
- T3/T4e Turbo
- Equal Length Manifold
- Downpipe (2.5")
- Intake
- Air Filter
- SS Oil feed line and oil return line fittings
- Charge pipes
- Turbo XS H34 BOV (ReCirculating)
- 340cc Injectors
- FMIC (31x6.5x3)
- Tial 38mm Wastegate (.4 bar)
-Secondary Fuel Injector Setup w/ SMT-6, Second fuel rail, Lines, Intake.
Tims 2.5 Exhuast in 2 weeks
Walbro Fuel Pump
NGK V-Power spark plugs
AND LOTS OF TIME
Old Jun 3, 2005 | 02:11 AM
peter_2150's Avatar
Good luck with install
Old Jun 3, 2005 | 08:07 AM
JonGTR's Avatar
You'll need a clutch. (Not Spec wink1.gif )
And if you're running the Walbro, then you'll need an aftermarket FPR. Not the B&M, a full replacement.
Old Jun 3, 2005 | 04:56 PM
gmantibby's Avatar
Who makes a good fpr? Not obx either! Is it beneficial to get one with only I/H/E?
Old Jun 3, 2005 | 05:29 PM
albert's Avatar
You don't mention....
hose clamps. You'll need lots of those. Along with Silocone connectors to hook the pipe up together.
Exhaust manifold gasket
Lines to run coolant/water to turbo/from turbo
Extra fuel line, and T Fitting to extend stock fuel line into second setup
Some form of ECU trickery? (SAFC SMT-6)
I also would reccomend a wide band 02 sensor (at least short term to verify tuning)
I would also reccomend an OBD-2 cable/software/code reader. You'll want to know what all those CEL's are, and need the ability to reset the ECU out of LIMP mode.
Old Jun 3, 2005 | 05:41 PM
hamhead's Avatar
Personally, as your going to have the engine torn apart already... this is the time where I would go and check over all my fluids/belts/filters/etc. to make sure your starting with good, fresh parts that won't cause problems later because they're old/worn.
You won't know what parts are missing until you get Tim's kit and see what gaskets, if any, he provides. 95% of kits have most of the parts, but not all. Count on several trips to autoparts stores for little pieces that are missing.
Old Jun 3, 2005 | 07:26 PM
Agarwal's Avatar
Huh... the guy asked for it.
