Daily Driven Tiburon 11.44@128
#41
thats right,if you look closer on the fogger is the same braided line making a "U" deleting the nitrous,that system were installed years ago and never been used but it will be used someday.the car runs that pass of 11.4@128 with vp c16 for a good reason.not punish the engine on that boost level(30psi) and pump gas.i use a torque plate to hone the block so no decrompression plate was used.regit,like i said pal,i did not use the spray.tom,i did not control timming but the car did 449hp and 25psi on pump gas so its not that bad.tom my car have stock valves not 1mm over.i use a microtech mt-4 fuel only to control well...just the fuel,the timming is totally stock and not modified by any external device.but you are right about the turbo size.any questions let me know!!!! thanks to all.
#42
#44
http://www.youtube.com/watch?v=TrVTEK72gik
#45
Vehicle: 2000 tib
WoW, so, low 11's on stock valves,no timing correction?,just pistons ,rods and a big turbo on race gas?? just wow!! ......may as well weld up a cage and go for 10's!!
#46
thats right,and even on stock cams.but well i have good parts,goon intercooler,good wastegate,good ECU,and of course a good driver and tuner!! me hehehe thanks
