clutch bushings
Old Jul 14, 2010 | 10:40 PM
rdgmk23's Avatar
Vehicle: 2004 hyundai accent
Default clutch bushings
can you use clutch cable bushings from an elantra on an accent since you can use a short shifter from an elantra on an accent.
Old Jul 23, 2010 | 07:18 PM
UrS0NvS's Avatar
yeah you can but if you take some time and looks up some things you will notice alot of people have gone to skateboard bearings and many other things that will work better.
Old Jul 23, 2010 | 09:12 PM
Skateboard bearings here. They require ever-so-slight modification to the diameter of the bushing holder, but they work oh-so-good. They provide a nice firm feel.
