wheel bearings
how tough is a wheel bearing to replace? I won't have to take my @#$%& rotors off again will I? I tried to search the forums, but for some reason the search function never finds anything for me...
QUOTE (tb1198)
... I tried to search the forums, but for some reason the search function never finds anything for me...
Yes, changing the bearings is a MAJOR PITA, and yes you will have to take your rotors out again. Sometimes they are stuck so bad you need a hydraulic press to get them out of the knuckle.
Yep, Zman is right on this one. lol.gif Rotors will come off. Dude, your probably searching in the author box. Go directly across from the description box, it doesn't have a white outline around it.
Uh huh.
Manual search.
I bet if you look, you can find a TON.
I happened to find 115 matches for Bearing in THIS sub forum.
Manual search.
