wheel bearings
Re: rotor removal
how tough is a wheel bearing to replace? I won't have to take my @#$%& rotors off again will I? I tried to search the forums, but for some reason the search function never finds anything for me...
Re: exhaust sound clips
QUOTE (tb1198)
... I tried to search the forums, but for some reason the search function never finds anything for me...
Yes, changing the bearings is a MAJOR PITA, and yes you will have to take your rotors out again. Sometimes they are stuck so bad you need a hydraulic press to get them out of the knuckle.
Re: Performance - Turbo, NX
Yep, Zman is right on this one. lol.gif Rotors will come off. Dude, your probably searching in the author box. Go directly across from the description box, it doesn't have a white outline around it.
NEED SOME MORAL SUPPORT, FROM FELLOW OWNERS!!!
Uh huh.
Manual search.
I bet if you look, you can find a TON.
I happened to find 115 matches for Bearing in THIS sub forum.
Manual search.
