Re: rotor removal
how tough is a wheel bearing to replace? I won't have to take my @#$%& rotors off again will I? I tried to search the forums, but for some reason the search function never finds anything for me...
Re: exhaust sound clips
<div class='quotetop'>QUOTE (tb1198)</div><div class='quotemain'>... I tried to search the forums, but for some reason the search function never finds anything for me...</div>
So I wasn't the only one... lol.gif Yes, changing the bearings is a MAJOR PITA, and yes you will have to take your rotors out again. Sometimes they are stuck so bad you need a hydraulic press to get them out of the knuckle. |
Re: Performance - Turbo, NX
Yep, Zman is right on this one. lol.gif Rotors will come off. Dude, your probably searching in the author box. Go directly across from the description box, it doesn't have a white outline around it.
NEED SOME MORAL SUPPORT, FROM FELLOW OWNERS!!!
Uh huh.
Manual search. I bet if you look, you can find a TON. I happened to find 115 matches for Bearing in THIS sub forum. |
