Oil starvation when autocrossing
Old Jun 24, 2011 | 11:15 AM
Carl's Avatar
Vehicle: 2004 Tiburon
Default Oil starvation when autocrossing
Whats the best way to prevent oil starvation when autocrossing? Im doing my first one next week and I want to make sure my engine is safe since I'll be beating on it. Also, is synthetic oil still the best to use when autocrossing? I have to do an oil change tomorrow too.
Old Jun 24, 2011 | 12:05 PM
Good quality synthetic is best to use only if your engine will be running. If you plan not to run the engine, it's not superior. Oil starvation: not much you can do. Run a flush before you drain your old oil and use an oil that is thin enough to pump. Otherwise, unless you want to fit an aftermarket external oil pump, that's about it.
Old Jun 24, 2011 | 01:45 PM
If your engine starts ticking badly you're running into issues. If not, you're fine. If it's ticking like mad and you go for another run it is asking for trouble (although that's what I do lol).
I wouldn't throw parts at it until you determine there is a problem.
Old Jun 24, 2011 | 02:03 PM
JonGTR's Avatar
Not much you can do? How about try building a better oil pan designed for racing with a larger sump and better baffling?
Old Jun 24, 2011 | 03:16 PM
If you have a problem, you could go a few different directions to ensure your engine remains properly oiled.
Here are my current plans, they may be similar to something you would want to try:
Completed-
High volume oil pump - did not help since it's a starvation issue (maybe even made it worse since it sucks up the oil quicker)
Phase 1- I have this already (except for oil temp) but still need to install everything-
oil cooler
sandwich plate adapter
oil pressure gauge
oil temperature gauge
Phase 2- I already know I need this but have not bought these yet.
Install new & improve upon existing baffles in oil pan
Accusump
Old Jun 25, 2011 | 04:04 PM
JonGTR how many betas are on the autox circuit with custom oil pans?
Old Jun 25, 2011 | 04:15 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
autox circuit?
Old Jun 25, 2011 | 05:07 PM
JonGTR's Avatar
I'm not omniscient. Perhaps you are and can answer this.
Originally Posted by WytchDctr
autox circuit?
Old Jun 25, 2011 | 08:58 PM
the question (for those in the back of the room) is rhetorical. Nobody (almost nobody) gets a $500 oil pan so they can prevent oil starvation on a $2000 car for one autocross event
P.S. please notice how an X comprises two lines. Those lines cross. Auto cross.
Old Jun 26, 2011 | 05:52 AM
Lol people are willing to spend 700 for a air ram on a 2000 car
2000 for a body kit on a 2000 car
Hell I probably have 10x what my car is worth in a turbo setup
A entire dry sump setup would probably be cheaper than 500 bux and would be well worth it on a designated autox car
Oh and for clarification I'm 90% sure they are making fun of you cuz you called it a circuit like its some sorta gran turismo challenge
