The Legitimacy of our 1/4 miles *split the 14 Sec NA tib arg
Old Jan 1, 2005 | 06:32 PM
Dweet's Avatar
Default Re: The Legitimacy of our 1/4 miles
<div class='quotetop'>QUOTE (CyberShark)</div><div class='quotemain'><div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>If the engine is in good shape, its cleaned, maintenence performed early, and its done on a DynoJet...(I don't use Mustang and other dynos, inaccurate) you will see those numbers. Similar engines on similar cars make similar numbers. :roll: </div>
nope, still won't be 175hp. :roll:</div>
agreed... you'll definately need the Ram Air and something to advance the timing to even think about hitting 175whp and probably a set of 270 cams rather than just the 1.8 Cams
Old Jan 1, 2005 | 06:50 PM
hamhead's Avatar
Default Re: Stock Dash mounted switches anyone???
I may be mistaken, as I don't own it, but I thought the MSD had the ability to advance the timing on the spark as well as retard it along with a 2-stage rev limiter, etc.
I'm assuming by Ram Air you're talking about KSpec's IM. Boring and polishing the stock manifold, which really isn't a bad design, would achieve similar/same results. I've been led to the conclusion you can bore out the stock TB to 58mm as well.
Even if you went with 272s, which wouldn't have to be high strength, you'd be about even with the turbo costs.
Ahh well, I'll leave this be until UltraTibby or someone else with most n/a mods beats me to a dyno. Plenty of 420As are making similar power with similar mods, but plenty of them have been monkeying around with n/a for years. None of you want to touch it. lol.gif
Old Jan 1, 2005 | 06:56 PM
CyberShark's Avatar
Default Re: What im up to...
sorry dude, turbo tibs own N/A tibs (don't know about the Korean Tibs). lol.gif I have most of the mods listed... lol.gif AND some you didn't
Old Jan 1, 2005 | 06:59 PM
hamhead's Avatar
Bleh, we'll see. I'll probably monkey around N/A for a while before I run some nitrous through the engine. laugh.gif Hell, I'm sure if I run 15.5 on stock tires and I/E I can get to low-mid 14s full n/a tongue.gif I may have less horsepower, but maybe I'm a better driver. lol.gif 60-foot times need work though. :?
Old Jan 1, 2005 | 07:00 PM
Dweet's Avatar
well my car has the BIM 58mm, BTB 58mm. AEM CAI, 4-2-1 header, 2.5" catback, Fidanza flywheel, Spec Stage 3 clutch, front and rear strut bars, S-AFC II, B&G lowering springs, KYB struts. I seriously doubt im pulling 175 whp.
Here is where your reasoning is wrong. The air ram IM is 68mm and betas respond like crap to NA mods. Its been proven
Old Jan 1, 2005 | 07:12 PM
hamhead's Avatar
Default Re: ebay rant
Depends on altitude, temperature, humidity, air density, car quality, and the intelligence of the driver. Didn't you run 15.1 or something with all of that?
I know Tibbies aren't the most responsive to n/a in the world, but I think a mid 14 on street tires can be easily pulled in the right situation. If the Air-Ram is 68mm, its a bit overkill for n/a. More suited for turbo use. Depending on how the IM bores out, I may have to make my own.
Old Jan 1, 2005 | 07:17 PM
CyberShark's Avatar
You'll still won't hit 175hp with the mods you listed. lol.gif :arrow: :twisted:
Old Jan 1, 2005 | 07:20 PM
hamhead's Avatar
Bah. We shall see, I leave this topic alone till I have my dyno. 8)
Old Jan 1, 2005 | 07:22 PM
Dweet's Avatar
I ran 15.1 with that plus a 50 shot, minust the S-AFC II
Old Jan 1, 2005 | 07:25 PM
CyberShark's Avatar
<div class='quotetop'>QUOTE (hamhead)</div><div class='quotemain'>Bah. We shall see, I leave this topic alone till I have my dyno. 8)</div>
The only way you'll hit 175hp is if you fabricate your dyno sheet or borrow a friend's..like I've said numerous times...
You'll never make 175hp with the mods you listed..not now, not when you dyno it, not ever. lol.gif :twisted: :roll: :arrow: wink.gif
