Other Hyundai Models Forum All Hyundai Forum. Discuss all other Hyundai models here that not listed anywhere else, such as the Hyundai Pony and Hyundai Scoupe!
Car Shaking
Old Sep 26, 2018 | 10:10 AM
Charlie Praphanthongchai's Avatar
Vehicle: 2017
Default MY TUCSON Limited 2017 Shudder when accelerate and indecisive with gear change
Hi,
I am new to this group. Sorry if I posted in a wrong section.
I own Hyundai Tucson 2017 Limited 1.6T 2WD.
I have few questions.
1. The problem just started 2 months ago. When I accelerate I feel my car is shaking sometimes (often). Sometimes it's just small shaking but sometimes it's a lot. I drive Uber sometimes and my customers felt it. I went to service and told them that I have this problem, they said it is normal but at first it didn't.
2. Is it ok if I do sport mode all the time including in and out of the city.
3. Is it possible to change from dual clutch to normal clutch
Last edited by Charlie Praphanthongchai; Sep 26, 2018 at 11:58 AM. Reason: more precise topic
Old Sep 26, 2018 | 08:37 PM
The shaking may actually be normal, depending what is causing it. Your car is new enough that the transmission fluid should not be low (but check the fluid level anyway), the transmission filter should not be clogged, and the driveline should not be wearing out. For grins, make sure the lug nuts are tight and inspect the tires all the way around, for damage to the treads. If your car stinks a little when you get out, you could have a stuck brake caliper. If you can figure out how to make the car *always* shake, so that you can do it on cue, make an appointment and drive one of the service people around when you make it shake. They can't deny it is happening, then, and won't have an excuse for not knowing that it is happening.
Sport mode all the time should be ok
Changing the transmission may not be practicable but I'm not sure. I don't think it was offered with a manual transmission at all but I didn't search for very long to find that out. If it was offered for sale with a conventional automatic, it may not be compatible with your engine. Either way, to change the transmission would be a very big, expensive job, possibly involving not only the transmission but also the wiring, computers, and pedals.
Old Sep 26, 2018 | 09:30 PM
Vehicle: 2017
Thank you. Noted!
Related Topics
Thread
Forum
Replies
Last Post
Tugger5000
HELP Forum
12
Feb 7, 2011 07:51 PM
Stocker
Engine, Intake, Exhaust
5
Jun 15, 2009 01:07 PM
zoned019
17
Feb 22, 2009 01:45 PM
j13760
12
May 30, 2008 11:56 AM
Bullfrog
9
Jan 22, 2005 07:31 PM
