Xbox Live Help
Old May 17, 2005 | 12:26 PM
SplinterCeL's Avatar
Well I've had XBL for about 3 months now, only problem is it won't connect
Old May 17, 2005 | 12:29 PM
00tibby's Avatar
are u using patch or crossover cat 5?
Old May 17, 2005 | 12:33 PM
javageek's Avatar
Did you mean your router is the WRT54G? If so you should not have any problems connecting. Go to Linksys and download the latest firmware.
Old May 17, 2005 | 12:53 PM
QUOTE (00Tibby @ May 17 2005, 06:29 PM)
I did when a directly connected it to the modem, but right now it is hooked up with a cat5e cable.
QUOTE (javageek @ May 17 2005, 06:33 PM)
Yes heh thats what I meant laugh.gif. I think I have updated the firmware, I'll try it anyway though.
Thanks for the quick replys laugh.gif.
*Update*
Upgraded firmware, now I get a new error . The new error is : Unable to continue do to technical difficulties. Please try again later.
Old May 26, 2005 | 07:18 PM
**Bump/Update**
I tried using using a shared connection with my PC, but I got a IP conflict do to having to add a second ethernet card, I fixed that by bridging the connections between the two cards. But I get the same "unable to continue do to technical difficulties" error :angry:.
Old May 26, 2005 | 07:24 PM
Okay, slow down. GO back, uninstall your router and everything else, make sure you put all the XBL settings back to factory defaults.
Then start over. Install your router, get the updates.
Then hook up the xbox and power it up. Make sure your settings are set as per your ISP's instructions.
Old May 26, 2005 | 07:34 PM
^^ I've done that several times under the direction of both sprint and xbs. Also I've posted on Xbox forums but no one replies to any tech help issues on there 02.gif.
Okay, slow down.
heh sorry I've had this problem since about the end of Jan. 02.gif.
Old May 26, 2005 | 07:41 PM
Sprint???
DSL?
Old May 26, 2005 | 07:45 PM
^Yes, It's the only fast thing available here.
Old May 26, 2005 | 07:48 PM
What's their web addy?
Something you might have to try is to directly connect your XBOX by it'self, directly to the modem. Reset the modem, and see if you have access.
Then work backwards from there. Comcast tried to sell me 2 internet accounts, but then I found I could just get a second IP from them and do it that way. With the router, you don't need to do even that (I'm running wireless now), but comcast couldn't figure out how to do it even thoughthey say they are XBL compatible.
