Zex Nitrous
To get a Nitrous system to work with a turbo, you would need a complete stand alone fuel management system, and/or it would have to be a "wet" setup, or you would need jumbo injectors!
"Wet" Nitrous setups add fuel in addition to the nitrous. 'Dry' setups just add nitrous.
If you were to go turbo...and get a Haltec, it would be capable of handling boost + nitrous...but...you would really only do that on a "drag" motor (motor that has the turbo near maxed out). Otherwise you could just turn up the boost PSI (and the corresponding increase in fuel) to add more HP.
