sound help!
Old May 14, 2004 | 06:15 PM
MADTIB's Avatar
Look at the internal air space of the Q logic.Then look at the spec's on crutch for the sub and see what the min sealed internal volume is.
Old May 14, 2004 | 06:18 PM
00tibby's Avatar
hmm they dont work, there only .65 and i need 1.2.....thx man
oh, will these 10" subs give out a pretty good baseline?
Old May 14, 2004 | 06:33 PM
tibwrcsbj's Avatar
yes they will,
and off the top of my head (i will look at c.field in a minute) the box you're looking at will do fine, but i will check right now.
Ok i checked the box is actually .65 PER sub
crutchfield does not have those particular subs on the site ne more, but i pretty sure they'll work just fine in that box.
Old May 14, 2004 | 06:46 PM
00tibby's Avatar
Default 97-01 elantra & tiburon G.P. lsd
crutchfield DOES have those subs, there just in the discontinued section...lol...heres the link
http://www.crutchfield.com/S-iB2QuuzVcXu/c...?i=158L1036&s=0
i went ahead and bid on 2 subs, and the amp....
Old May 14, 2004 | 06:53 PM
tibwrcsbj's Avatar
You can go ahead and get the box too, especially if you get it from crutchfield, they send a bag of polyfill w/ the box, so it would work out fine. most subs have a tolerance after the box volume they work best in, i believe that its usually +- 5%, the subs need .7 CF the box is .65 CF + the polyfill and the subs would be performing like they were at the higher side of that +-5%.
so again you should be good w/ the box too.
Old May 14, 2004 | 06:59 PM
00tibby's Avatar
cf? and i was thinking bout getting the one from ebay, what else would i need if i got the one from ebay?
Old May 14, 2004 | 07:09 PM
tibwrcsbj's Avatar
cf is either CARBON FIBER(my favorite) or CUBIC FEET......... this is what is being referred to in the the context of this thread,
thats the amount of air that the sub will sit in........the amount of air the sub sits in is very crucial to how it performs (each sub is different in its' requirements)
if you are getting a qlogic box off of ebay, go for it, but just make SURE its the same box as the one on crutchfeild.
Old May 14, 2004 | 07:17 PM
00tibby's Avatar
so ur saying i can the .65 cf box for the .7 cf subs.....ok thx
also, what else do i need for my subs to work......
Old May 14, 2004 | 07:23 PM
MADTIB's Avatar
I don't want to get into too much detail with you, but I'm not too sure about the volume for that Q box.The bass is probably going to distort on certain low bass frequencies.
Old May 14, 2004 | 07:30 PM
00tibby's Avatar
thx for all the help! i think i kinda understand subs now....
