Soldering...
Old Dec 21, 2004 | 01:48 PM
supercow's Avatar
Default Re: Official Member Listing of Crooked H
QUOTE (tibby01)
check in here.
the stand for it sucks. i found that the center hole in my soldering spool i PERFECT size for it though.
Old Dec 21, 2004 | 04:55 PM
Default Re: 97-99 ARK exhaust system on stock
sorry....
http://rdtiburon.com/index.php?name=Forums...viewtopic&t=109
Old Dec 21, 2004 | 10:21 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: Alpine vs. KSPEC
Oh course don't forget the other things you can use the butane for too. I have a butane torch and it helped with removal of hockey stick blades from aluminum shafts. Multi-use equipment is great.
Old Dec 22, 2004 | 07:33 AM
MADTIB's Avatar
If you are splicing wires, I wouldn't bother using solder.It's time consuming and an all around PITA.Just use butt crimps and a crimping tool.It makes a great connection as long as you do it right, and it's much faster.
If you are hell bent on soldering wires, just make sure you splice them together real well before applying the solder.
